APX6000/4000XH reception against VP6000
williewhyte
Calgary
Has anyone ever encountered a difference between the radios receeiving signals. Specifically Motorola radios picking up the signals & VP6000 not hearing anythng?
It is a Motorola P25 800Mhz system, the radios have all been bench tested on different Viavi test sets and passed. Have spoken to othere in different areas and they mentioned same thing.
KevinC
The big K
Super Moderator
1 point
I’m not a Kenwood guy, but I’d imagine they would be pretty darn close in their specs, both RX and TX.
Are they not receiving at all or are they missing calls or something else?
williewhyte
Calgary
They not hearing the calls. Its not an occasional happening. Users reported different locations & in differnent strength areas. Assuming it must be the programming or difference between motorola & kenwood.
williewhyte
Calgary
Sorry they hear some stuff, just miss some calls when the motorolas hear them.
KevinC
The big K
Super Moderator
1 point
Again, not a Kenwood guy, but if the system is simulcast are the radios set to LSM/CQPSK (assuming Kenwood has a setting for that and doesn’t try to automatically decide)?
williewhyte
Calgary
No nothing as fancy as that. Just a straightforward astro system. Did call EF Johnston and nothing from them. They not aware of anything.
williewhyte
Calgary
Something is up ,KENWOODS have excellent receive.
Am Motorola & with these Kenwoods codeplug a little strange although seems srtaightforward. . Have checked the codeplug and cannot see anything wrong. but again could be I'm missing something.
WB5UOM
Have you checked the modulation type as mentioned earlier?
I don't have access to it, but this sounds like maybe checking to see if you are running the latest firmware in the radios would be a good step.
Unrelated, but I had a bunch of early NX-410's that were giving me issues with missing calls on my trunked system. Kenwood fixed that in firmware and they've been fine ever since.
WB5UOM
mmckenna is right, on a TRS I have seen a radio trunk off to a distant site that it then cant access...update fw and it fixed it...forgot about that
jeepsandradios
East of the Mississippi
Uh...any astro system will be programmed for either C4FM or CQPSK. That the modulation of the system. You need to know that to do it with the Kenwood. Unless its a single site it is most likely CQPSK. Ive run into this with other vendors on both P25 simulcast as well at trunking.
wd8chl
And frankly, I program pretty much all radios for LSM instead of C4FM. It seems like that works on everything, even though it's meant for simulcast. We've also seen lots of problems with radios going to sites they shouldn't. That seems to be an issues more with the system or with an obscure setting in s/w somewhere.
Current f/w for Viking is 8.40.20, or .21 for the VP8000.
MTS2000des
5B2_BEE00 Czar
Have zero issues with Viking radios on our A25 2022.1 M-core 15 site LSM system. Your system owner/support team can and should be driving your codeplug/template development. Get with them and confirm, but most likely mod type should be set to CQPSK.
williewhyte
Calgary
Thanks for the input guys, will follow up. am going to check codeplug then reach out to EF Johnson again.
