APX7000 Cloning Question
N9JIG
Sheriff
Moderator
Far NW Valley
I have a growing fleet of APX7000's at work and we have an agreement with the system owner that allows us to program the conventional channels of the radio and I don't diddle with the trunked stuff. The trunked system is protected with an ASK anyway...
I can read the radios, edit the conventional channels and features, then write the changes with no problems at all. What I can't do however is clone the radios. I presume this is due to the lack of an ASK.
Is there a way to set it up so I can read/edit/clone just the conventional channels and leave the trunked stuff as is or is it 'all or nothing'?
davidgcet
not clone, but drag and drop will do it just fine. what you do is open the CPS 2x. in one you open your "master" template, in the other you open the target radio. then in the master click and hold on your conventional personality and drag it over to the other radio and "drop" it. there is a tutorial in the software on how to do this.
i HIGHLY recommend you save the original archives of each radio before doing anything. i save them as Radio_X_original, then the change Radio_X_rev1, then rev2, etc.. this way should you accidently screw up a trunked zone(you can delete channels but not add/re-add them) you can simply back up to the original archive. later on once you are 100% positive everything works you can delete the original and keep only the most current archive.
