APX7000 VHF 700/800
draftinjoe
I have a apx 7000 vhf and 700/800 that i have programmed up for NAS on a phase 1 system. I am trying to get it to work on a phase 2 harris system which the county i live in is on P2. i see it stopping on the talkgroup but no audio. What am i missing??? Johnston County NC
KevinC
The big K
Super Moderator
1 point
Either you don't the proper flashcode for TDMA or you don't have the proper bandplan for TDMA.
draftinjoe
and yes my radio is flashed for TDMA. wouldn't give me the option to use FDMA or TDMA if it wasnt. Attached is a pic someone sent me and i put those into the radio. Cant or dont have a option for starting point 0 so its in slot 1 FDMA and slot 9 for TDMA
draftinjoe
Sorry didn't mean to sound rude. Ok update. Its picking up Smithfield PD and selma Pd only. Its stopping on others but no audio. So I made progress but would like everything to work.
KevinC
The big K
Super Moderator
1 point
If all the TG's are TDMA and you hear any of them it's not a programming issue. Maybe those others are encrypted?
draftinjoe
Negative on the encryption. Had no issues with my G5. Guess crazy question is how do you tell if they are actually TDMA? I've been told some aren't on TDMA. So they are basically running phase1&2
KevinC
The big K
Super Moderator
1 point
1 or other band plans? So in theory I need other slots filled not just 1 & 9?
You need one TDMA and one FDMA bandplan element for each frequency band (700, 800, whatever). If you are hearing any calls at all at least one of them is correct. I can't tell you which one is correct.
And this is all assuming you have no other issues going on.
Twister_2
Dauphin County, PA
Did you do the little inter-WACN trick that is necessary to successfully follow a Harris system?
I've never had any issues monitoring Harris systems with various APX models. The key is to have the correct band plan (aka ASTRO 25 Channel ID), otherwise it's not going to track any voice activity. I normally set coverage to either SmartZone or Inter-WACN, set the SysID and WACN to the real values, disable Motorola Proprietary Features, and disable Validate NAC Against System ID.
Twister_2
Dauphin County, PA
I'm a goober, I meant on the FDMA. Sorry again.
Some TG's work so I wouldn't expect that to be it.
It's impossible to say with any confidence without seeing the code plug but I suspect the OP is able to decode the FDMA but not the TDMA due to the inter-WACN & SYSID/WACN settings.
