APX7000 Won't Scan!
Jersey Shore
#1
Hi,
Just finished programming my APX7000 radio. Setup 5 zones, and 2 scan lists. I programmed my top orange button to scan, however when I push it, it just beeps like an programmed key and does nothing. Also, if I try to add the scan menu items, it wont show up after writing to the radio. I never had any of these issues when programming my XTS radios. How can I get the radio to scan? Is there a Scan programming feature when I can add and remove from scan lists from the front panel of the radio like I was able to do with my XTS's? Thanks!!
#2
Did you link the personality to the appropriate Scan List? You do that under the Feature Tab in the Conventional Personality area.
