APX7500 functions
tvining
Fort Wayne, IN
We have an APX7500 and have activated "TONE REMOTE" Operation.
The radio is receiving the tones, but the 'functions' are not defined.
where do we tell the radio that Function 1 is change to Zone1 Channel 1, Function 2 zone 1 channel 2, etc?
We can't find it in the web menu or the codeplug software. I'm sure it is there, just can't find it.
xmo
The Consolette controller card is configured using a standard web browser running on a computer.
Additional programming software is not required as the application resides within the Consolette.
Supported connection methods include USB and Ethernet.
See page 3-19 in the APX service manual P.N.: 68009482001B
tvining
Fort Wayne, IN
We have found the web GUI, and have told the radio Tone 1 means perform Function 1.
But I can't find anywhere to tell the radio what function 1 is.
xmo
From APX manual # 68009483001C
TRC Supported Functionality
Channel – The dispatch console user uses the Select Frequency command to change the Consolette’s radio channel. This will select items such as a talk group and an air interface type.
The number of channels that can be changed by the dispatcher is 14.
NOTE: Selection of 16 channels is possible if the tone table is set up to not use Coded/Clear
operation.
When a Select Frequency command is received from the Console, the Consolette will send a message to the mobile radio to steer it to the channel requested.
The channel number from the Console is mapped linearly to a zone and channel in the mobile radio. For example, if each zone has 5 channels, and the Console requests channel 8, the Consolette will steer the mobile to channel 3 in zone 2.
If the mobile does not allow the indicated channel, the Consolette will generate a “bonk” tone and remain in the current channel.
tvining
Fort Wayne, IN
I will try again. We were getting PTT, but the radio was not changing channels when the appropriate tone was sent. My assumption is that the radio is getting tones, because it's getting the PTT, but it's not responding to them.
That's why when I was sending the "f1 select" tone, I thought it was "Function 1". You're saying it's frequency 1. Is there a reason why when I send the f2 tone, it would not be switching to frequency 2, as indicated above should happen?
Page 4-8 of the 68009482001C says "The frequencies can be mapped to functions in the Consolette codeplug."
My apologies for not conveying well what we are seeing, My first time working with Motorola Tone Remote.
tvining
Fort Wayne, IN
We got these working! The positive and negative were reversed on the input audio, and when corrected, got us up and running.
Thank you all for the help!
This operation is really slick now.
