APX APX8000 - Battery Indicator not displaying
VA3ADP
Mississauga, Ontario Canada
I recently bought an APX8000 from a eBay dealer I've dealt with in the past. He did not ship the radio with a battery so I ended up buying an PMNN4486A. I already had the NNTN8445A charger laying around from a previous radio.
I turned in the radio and the battery indicator is not showing. Furthermore, I cant seem to force the battery into recondition mode on the charger. My thought is there is something up with the charger or battery since it won't recondition on its own.
I am not sure if I am potentially doing something wrong.
Some advice would be much appreciated.
Thank you!
GTR8000
NY/NJ Database Guy
BEE00
I think you mean NNTN8845. There is a switch on the bottom of the IMPRES 2 SUC that disables conditioning mode. Check that, try again.
K2NEC
39A
Is the battery new? If not, the Impres chip may be bad.
Additionally, try draining the battery until it says it's low then try forcing a recondition cycle. For some reason I've had that work before
