APX8000 only one internal mic working
W6VVM
Can anyone point me to a setting in CPS that could possibly be the culprit for one of the two internal mics not working?
The mic on the rear (screen) side is either barely working or not working at all. Nothing is jumping out at me in CPS. I have switched between various profiles but there is no difference.
In the profiles under Microphone/TX Settings > Custom Noise Reduction, there is a setting called “Directivity Mode” that caught my eye. It is set to “On/Adapting” and grayed out. Not sure what other setting is locking it. I didn’t think it was even possible to disable one of the onboard mics (short of connecting accessories). So I’m half wondering if I have a hardware issue.
MightyMan
Is the Model new? It could be damaged or faulty from when it was in the factory- Either way you should send it to Motorola
W6VVM
Not new. Out of warranty and really not sure when the issue began. I’ve heard suggestions that CPS R30 could have corrupted something but can’t really confirm. I updated to CPS R32 and the issue remains.
hitechRadio
If you have your one of your radio profiles under radio ergonomics set for Extream that could cause it. Assuming radio supports it in the flash, called Extream one-sided feature.
Also under radio ergonomics wide, make sure the active mic is set correct under advanced.
You will need to have view set to expert mode I think to edit it.
Always back your codeplug before making changes.
W6VVM
Thanks, I went through all the profiles in expert mode and tested various settings. Setting different active mics to active/inactive confirmed that one of the mics doesn’t function. So I think it is hardware. I’ll have the radio serviced.
