AR5000A & OmniRig Control - Interference
osros
Gainesville, Texas
Wondering if anyone else with AR5000A using OmniRig radio control interface is getting a popping or pulse from the RS232 connection? Every time its activated I hear the popping and it only happens with OmniRig. I have One or two other applications that don't use omnirig and all seems fine. This popping effects everything, can see on meter, spectrum display, and hear it.
The popping seems to be related to the Poll Int, ms. I can adjust this setting and the popping increases or slows now but cant make it go away.
I already tried 2 Pcs with same results, I will see what I can do for better grounding but cant go crazy not perm setup for radios.
Anyone gets this also or have any suggestions to get rid of it!
snackers7
Victoria
AR5000A & OmniRig Control success.
Managed to get my AR5000 finally working with OmniRig/SDR-Radio/Windows10/
Go to/join the........... Yahoo Groups: ar5000 group ...............
And the ini file in the files section you need is called......... AR5000-v05.ini
Had to use my Hackrf to receive the 10.7mhz output from my Ar5000 in SDR-Radio software.
An RTL would need an HF converter to be able to receive the 10.7mhz signal I think.
Not perfect but it is pretty good. All the other ini files around pulse and pop.
Can be a bit of delay changing freqs,Though at least it works.
cheers Tony.
Otiselevator
Ar5000 omnirig
Anybody have a link to the referenced ini file mentiuoned above, I'm currently having the same problem...
Thanks in advance.
Otiselevator
Modified an RTL SDR dongle for 'direct sampling', win 7 comms working now with HDSDR.
AR5000-v05.ini attached as txt, rename to .ini
  • AR5000-v05.ini.txt
