ARC 250 Software
JohnFerrera
Can someone who has used this software tell me if this software makes programing the truncking part of the BC796D easier than trying to follow the manuel?
Thanks,
John :x
scannerfreak
Moderator
Indiana
Using any software to program any scanner is much easier than doing it manually. You still need a general idea of how the scanner works, but the software helps you greatly. ARC is well worth the money for programming the Unidens.
signal335
Great Stuff
I use the software for my 785D and my 250, and it makes life much easier when programming
