ARC 996 USB Cable Can't Communicate
Birmingham, AL
#1
Scanner Master Bearcat USB Cable
First I downloaded PL2303 Driver for Windows XP (not Vista) and ran that program.
I have "Restarted" Windows.
Open ARC996 and attempt to READ DATA.
I get ARC 996 Error Message:
Serial port is not available or used by other software.
I have the USB plugged into the front USB port on Inspiron 530 w/ Windows XP
Thanks......
New Jersey
#2
Thanks......
Look in the device manager to see what port was assigned to the cable, make sure the setting is the same in the software.
Birmingham, AL
#3
Found Driver ComPort 4
After clicking around some, I went into ARC 996 and found COM Port 4.
That got her going.
Thank you for your help.
And thank you for your service to the USA sir!!
Scan On!!!
New Jersey
#4
That got her going.
Scan On!!!
I'm glad I could help, and thank you! :)
