ARC XT PRO Won't recognize scanner
Zippomeister
California
I'm running Version 1.4 Build 5 of ARC XT Pro. (ie the latest greatest)
It's the "full" version (ie I paid for it)
Windows 32-bit Vista, w/all latest updates
Using Uniden cable w/ Prolific driver (i.e. USB-to-serial converter cable)
Have uninstalled/re-installed program
ARC XT won't recognize either my BCT-15X or BC346XT.
When I ask the program to "autodetect" it complains there's no scanner hooked up.
When I manually designate the correct COM port, same result when it tries to read from the scanner.
Ok, many folks around here are running ARC XT without this issue, so the basic software can't be all that bad.....any suggestions on other items to check, or known incompatibilities??
Thanks, Zip
update your cable divers to the latest version?.. make sure comports in the sw matches what i shown in windows
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Do you have control channel output set to 'on'? I know that gives FreeScan fits - might also be the same with ARC XT 73 Mike
Zippomeister
California
AlamabamaRS: Yep, got the recommended driver for the Uniden cable
Mike: Tried Control Channel Output Setting both On/Off....no change
Gommert: Are you referring to "PL-2303 Vista Driver Installer.exe" ?? Yes, I have that driver installed.
Ok, any other ideas?
Kennrth
Bay Shore Long Island NY
When you open Device manager, when you plug in and unplug the cable, you should see the device appear and disappear. If not try to reinstall driver. If it isn't appearing as a COM port, you need to go into its properties (when plugged in), select "UPDATE DRIVERS", then point the computer to the appropriate file
You must diconnect usb cable before installing drivers
Read this ?
Connecting scanners via USB - The RadioReference Wiki
and this
http://www.bearcatwarehouse.com/index.asp?PageAction=VIEWPROD&ProdID=133
You sure it is a usb special cable for uniden not radio shack?
Zippomeister
California
Thank you to all who offered help and suggestions.
Got the program to recognize both of my scanners now.
*AND* got 'em working with both the Uniden cable and a prior-purchased Radio Shack USB-to-serial cable....
---Zip
