ARC125: ARC125/Uniden issue
JohnBN
I have ARC125 Installed and registered, I put all new frequencies in and pressed send, it found the scanner, it went through all banks etc and said "end communication" once it had finished, I looked at my scanner (says under remote control while stuffs being sent to it) and once its done I scrolled through to find its all of the old frequencies still and nothing was sent! tried this multiple times and no luck
Help, please?
Scan125
UK
I'm not familiar with ARC125 but I assume you have the correct port and speed set?
After sending to scanner have you tried loading back into ARC125 from the scanner?
Initially suggest you try a different USB cable just in case the one you have is broken.
You can also use my free/charityware Scan125 Control Program to see if that communicated and loads/controls your scanner OK.
Hopefully we can rule out a broken scanner / cable then you are looking at a software issue.
