Arc246
jerrylittle
Reno Nevada
I have Arc246 software I have been away from scanning for a long time. I need a little brush up here and there. Can anyone tell me if 131.70000 and 464.60000 numbers are set up using conventional or motorola type 2 etc etc are? And or DCS/CTCSS, AM, UHF, etc. Thank you for any input.
131.700 is AM Aircraft( conventional), 464.600 is FM, could have PL's depending on the area you are in. also 464.600 could be APCO25 digital or Moto or anything Need more info
