ARC396 - substituting 0 for freq
kg4pbd
Has anyone else run into this:
A conventional system correctly shown in the software editor but when I write it to the radio it substitutes a "0" for the frequency for on one channel. Everything else transfered correctly.
It only happens to conventional systems and I happens to more than one though I haven't discovered a pattern.
Thanks,
kg4pbd
Thanks Gommert,
I'll give that a try tonight. I do have the beta version but I think I was using the older one when I did that transfer.
Take care,
kg4pbd
That was it. I downloaded the newer version and it worked perfectly.
Thanks for the quick reply Gommert
