ARC500Pro and RS-197 scanner issue
HarleyOne
Why can't I seem to load my Type I Fleets & Subfleets correctly?
I load my them as such:
56016 Main Line
56032 Yard Ops
56096 Riverline
56048 Maintenance
56064 Security
56080 Supervisor
24064 South Central Tr
22016 South Risk Manag
19968 South Facilities
17408 South Vehicle Ma
23552 South Tactical
17392 South Transporta
20992 South CSS
20480 South Procuremen
54416 S PATROL
54432 S PATROL AUX
54448 S REGION 1
54464 S REGION 1 AUX
54480 S REGION 2
54496 S REGION 2 AUX
54512 S OEM 1
54528 S OEM 2
54544 S NJT BLUE
54560 S NJT RED
54576 S SPEC OPS 1
54592 S SPEC OPS 2
54608 S SPEC OPS 3
54624 S SPEC OPS 4
54640 S SPEC OPS 5
54656 S SPEC OPS 6
54672 S DETECTIVE
54688 S DETECT AUX
54704 S FIELD COMP
54720 S SPEC INVES
54736 S COMMAND 1
54752 S COMMAND 2
* Wildcard 1
* Wildcard 2
200-00 S. NJTPD ANCMT
200-01 S. EXEC
200-03 S. C. TRANS
200-05 S. OPERATION
200-06 S. ENG/RES
200-09 S. RSS
200-10 S. ADMIN
200-12 S. RFFU
200-13 S. RAIL COMM.
200-15 S. CNTRL CNT
101-00 S. NJTPD ANCMT
101-01 S. PATROL
101-02 S. COMMAND
101-03 S. PD AUX
101-04 S. FIELD COMPL
101-05 S. DETECTIVE
103-00 Red Cross ANCMT
103-01 Red Cross 1A
103-07 Red Cross 1G
And they display as such:
56016 Main Line
56032 Yard Ops
56096 Riverline
56048 Maintenance
56064 Security
56080 Supervisor
20992 South CSS
54416 S PATROL
54432 S PATROL AUX
54448 S REGION 1
54480 S REGION 2
54512 S OEM 1
54528 S OEM 2
54544 S NJT BLUE
54560 S NJT RED
54576 S SPEC OPS 1
54592 S SPEC OPS 2
54608 S SPEC OPS 3
54624 S SPEC OPS 4
54640 S SPEC OPS 5
54656 S SPEC OPS 6
54672 S DETECTIVE
54688 S DETECT AUX
54704 S FIELD COMP
54720 S SPEC INVES
54736 S COMMAND 1
54752 S COMMAND 2
* Wildcard 1
* Wildcard 2
200 S. NJTPD ANCMT
200 S. EXEC
200 S. C. TRANS
200 S. OPERATION
200 S. ENG/RES
200 S. RSS
200 S. ADMIN
200 S. RFFU
200 S. RAIL COMM.
200 S. CNTRL CNT
101 S. NJTPD ANCMT
101 S. PATROL
101 S. COMMAND
101 S. PD AUX
101 S. FIELD COMPL
101 S. DETECTIVE
103 Red Cross ANCMT
103 Red Cross 1A
103 Red Cross 1G
Coverted
Ottawa, Ontario
Can you hear the frequencies/trunk groups? If you can ARC500 did its job. If you want to see all the information. Check off the CC Dump and the DSPDump in the expert section of the software and re- upload to the scanner. That should give you all the information available to upload to your Pro 197.
