ARC95 "Priority"
MurrayBrown
Winnipeg, Manitoba, CANADA
At the advice of several, I purchased ARC95 software for my new-to-me Uniden BC95XLT. Very straight forward and the manual is quite understandable ....
EXCEPT .... I can not find abywhere in the manual where it outlines what can and/or cannot be done with the column entitle "Priority".
I am a newbie to scanners, so please bear with me with your repoonses. Thanks in advance! :)
rk911
Rich
Wheaton, IL
if the 95 is like every scanner I've ever had the 'Priority' channel(s) will be sampled continuously. Try hovering the mouse pointer over the column in ARC95 to see the options for that column.
MurrayBrown
Thanks. I did. There were no options. I could change from Off to On and vice versa. For the time being I'm going to select "On".
a417
KevinC
The big K
Super Moderator
1 point
If you don't have any channels checked for priority then on or off probably won't make a difference. I'm guessing that model lets you select which channels are priority (some were hard coded to the first channel of each bank IIRC).
