ARC996 v2 troubles
D
DaveNF2G
Guest
Since updating to ARC996PRO version 2.10 Build 2, I have been unable to:
- add new Sites to existing trunked systems
- paste complete site data to Systems (leaves out frequencies)
- save frequencies (re-)added to Sites
Also, the focus moves strangely when tabbing through the Frequencies tables. It always tabs backward one cell before going forward.
:confused:
Butelsoftware
Dayton Hamvention
When editting systems make sure that the system has the focus in the system browser, so either click on the system icon or the blue 'S' icon, then add and paste should work.
I can't duplicate the trunk freq tab order problem, I need a more detailed description how to duplicate.
Gommert
www.butelsoftware.com
D
DaveNF2G
Guest
I don't know what to tell you.
I click on either the System name, the sites folder icon, or any site, then click the add SITE button and nothing happens.
I have also uninstalled and reinstalled the program. The uninstall wasn't clean; it still knew my registration number when reinstalled.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Tab order is seriously screwed up in ARC996. In the "Edit Groups" box, for example, tab takes you backwards through the group name field, from 10 to 1 and then to 11, then to the 'Active' checkbox for group 3 (?!?).. then the active checkbox for group 4, etc., on through to the active checkbox for group 10, and then goes to the group name field for group 12... I gave up after that. IMO, it should go from the 'Active' check box for group 1, to the 'group name' field for group 1, to the 'Qkey' pull down for group 1, to the 'L/O' check box for group 1, and then to the 'Active' check box for group 2, etc. Only after going to the 'L/O' check box for Group 20 should the tab order move to the buttons at the bottom of the dialog box.
On the main frequency/talkgroup page for any system, either Alt+Tab into or out of the application causes the cursor/focus to move back one cell.. example - if in the Frequency cell on row 2, Alt+Tab away and then back and you end up in the Comments cell on row 1. Do it again and you're in the Audio Type cell on row 1, etc.
There are a number of other bugs:
- Using the double-click/space bar method to move through the options of the "Record" field malfunctions. The options available when pressing "Tab" cycles through Off and then 1 thru 9, not Off and On.
- Right-clicking on a line and selecting "Remove Selected Lines" intermittently/randomly instead fills all remaining lines in the system/group with the selected line.
- There is no undo function, making the above situation very very very very very annoying.
