Are older Orions rebandable?
#3
So that means we can purchase a 900 MHz Orion and reband it and run it on 800 MHz ?
Would you have to change the boards inside . . or what would be involved ? Just from what i have seen the logic boards are excessively priced and rebanding would be way too expensive to be worth it.
#4
Sorry, I didn't think I had to be so specific and overstate the obvious. All 800MHz Orions and MRKs are rebandable.
