Are there multiple RTL-SDR V3 software options? If so, which is best?
Omega-TI
Ω
Washington State
Okay, I pulled the trigger on a starter unit, the (RTL-SDR V3). Is there more than one software package available for this rig? If so, is there consensus on which piece of software is best? The reason I ask is because I've never really be into removing programs just to install something else that does nearly the same thing. I figure you guys are the experts here, so why not ask BEFORE I fuss around getting it set up.
cmjonesinc
What are you trying to accomplish with it? If you're using an sdr as a trunked scanner, DSD+ Fastlane is the way to go. If you're wanting to explore the spectrum, SDR# (SDR Sharp) is really good. There are other options but those are really popular and have good support.
Edit:
Good choice on the v3. For the money they work very well.
Omega-TI
Ω
Washington State
Thanks! Actually there are no trunked systems in my local area (to my knowledge), so that made the choice easy! :D
With that in mind, I took your advice and downloaded SDR Sharp. Now all I have to do is wait for the slow boat from China to arrive...
dlwtrunked
You should note
Omega-TI
Ω
Washington State
You should note
Yes, that's where I went. (y)
I tried Scamzon first, but they were out-of-stock, so I clicked the Ebait link instead
Omega-TI
Ω
Washington State
BITD I used to do packet radio with MIR and the ISS, that was the extent of my digital stuff, but packet has sort of died off. Will DMR decode AX25?
AB5ID
Lee's Summit, MO (Kansas City)
SDR# will not decode digital signals. DMR seems to be everywhere, so you may want to expand/modify your choice.
u2brent
OAMPT
KRWDPAXKRS1
Some suggestions for software can be found here..
west-pac
I use SDR#, with a Virtual Cable (downloadable software that works in the background to pipe the digital audio from SDR# to DSD+), connected to DSD+ Fastlane for finding and decoding DMR, NXDN, and P25 systems.
For P25 sites I use the Unitrunker software for logging Radio IDs and Talkgroups. You can use Unitrunker for all your P25 needs, but I just find it easier to search and find P25 systems and sites on SDR#/DSD+, and then switch to Unitrunker for gathering and logging RIDs and TGs. IMO, Unitrunker is visually more appealing with its customizable colored tags for easy deciphering of individual Radio IDs and Talkgroups for P25 sites.
Those are the 4 pieces of software that I have used with my RTL-SDR. There are other softwares, such as OP25, and SDRTrunk, but I've never used those, and don't even know what their user-interface looks like.
As far as not having any digital radio systems locally, I bet you have some; most states have a statewide P25 radio system. Whether or not your local agencies use it may be a different story, but you'll still be able to gather data from the sites and systems. A lot of states and regions have similar wide-area DMR or NXDN radio systems that businesses can lease channels on to use for their business. Typical users of those business systems would be businesses that use many vehicles, such as school buses, garbage trucks, taxis, tow truck companies, public transit buses, private ambulance transportation companies, road construction crews, etc.. Here in my area, all of the large hospital networks (each with hospitals in several different counties) have their own digital radio system that links all of their hospitals together. Also if you're near any military installations or General Motors automotive plants, they have large, nationwide digital radio systems; as I'm sure many other large, nationwide businesses do as well.
With an outdoor antenna connected to your SDR dongle you'll be amazed at how many digital radio systems you'll find. I have an outdoor antenna at 25ft, on top of my house in east-central Indiana, and I've found and decoded radio systems from Ontario Canada, to Wisconsin, to Missouri, to Virginia, and everywhere in between, along with dozens of sites and systems around my local counties.
I also take my laptop and SDR in my vehicle to chase and track down new sites and systems to help build-out the RRDB. Duke Energy is building a new nationwide P25 system in several states, several of the sites were online in southern Indiana but they were not listed on RR, so my other-half and I took a roadtrip. When we got into the target-area, as she drove down the highway, I found and logged the new Duke sites on the laptop, then submitted my finding to RR that evening.
Needless to say, I enjoy hunting for new systems and sites 🤣, and RR could always use more people submitting accurate data.
Paco-Jerte
You Member, Member!
34.0500° N, 118.2500° W
I Have the RTL-SDR V3 ordered from Amazon (no antenna kit) and using a Discone Antenna works great and use the following softwares depending on my use/needs. And believe me they all different and work as follows:
DSD+ Fast Lane - Great for P25 Conventional (LAPD and others) + DMR + NXDN +Dstar + DIgital Trunking. Not so great with Simulcast.
SDTRUNK - Working excellent even flawless with Simulcast.
OP25 - Works great too and flawless with Simulcast.
All these softwares running on an ACEPC AK1 and an outdoor Radio Shack Discone antenna.
Since you said you will use WIn10 then the first 2 is what you want. If you decide on OP25 then go with Ubuntu 20.04
R0am3r
Salt Water Conch
Oneida County, NY
Paco-Jerte - I have never had a problem with DSDPlus Fastlane while monitoring a P25 simulcast system. I'm wondering if you are experiencing other issues (e.g. weak signal, incorrect bandwidth)?
Omega-TI
Ω
Washington State
Since I'm planning on having a lot of funs fun with this little gadget, and you guys here are so great, I snuck in a little plug for this amazing radio site...
Omega-TI
Ω
Washington State
My main concern is that the Chinese sells both real V3 and fake V3 which is discussed on the page. I assume you ordered a real one.
Yes, that's why I followed their link to their "RTL-SDR-BLOG" sales page on ebay. Trust me, I'm paying attention to all the warnings and suggestions all you experts are kind enough to share. I've been out of this hobby for so long, much of it is new to me.
