Are These Sites Going To Be Re-banded?
Spirit
Northern Colorado
#1
Are these sites going to be re-banded? Or will they remain the same now?
101 - T0101 - 868.23750 # Admin
102 - T0102 - 868.91250 # Riley Peak
103 - T0103 - 868.52500 # Silver Heights
104 - T0104 - 868.93750 # West Creek Counties / I-25S
105 - T0105 - 868.97500 # Mount Thorodin
106 - T0106 - 868.85000 # Squaw Mtn Counties / I-70W
107 - T0107 - 868.87500 # Smokey Hill Southeast
108 - T0108 - 868.77500 # Lookout Mtn
110 - T010A - 868.25000 # Franktown
164 - T0140 - 868.83750 # Chevron Plaza Tower
Thanks a lot for every ones help...Very much appreciated!!!
Evans, CO
#4
What about the following:
322 - Adams Co Simulcast
170 - Auraria Campus (Denver Metro)
171 - State Capital (Denver Metro)
120 - DTB (Denver Metro)
I'm going to assume no, since they're either 700MHz or in the case of DTB 853 and change.
-- B
jimmnn
Colorado
#5
-- B
322, 170, 171 no change since they are already 700MHz sites.
120 was re banded early on so it's done as well.
Jim<
Front Range of Colorado
#7
The RR database is showing 38 sites that still have a control channel above 860, IE not rebanded. Is this correct?
-Mike
SiteNumber SiteName
101 Arapahoe Admin
101 Cheyenne (South)
102 Riley Peak
103 Silver Heights
104 Beacon Hill
104 West Creek
105 Mount Thorodin
106 Squaw Mtn
107 Smoky Hill
108 Lookout Mtn
109 DRDC CF
110 Franktown
111 Mines Peak
112 Mead
116 Vertamont
123 Ramah
124 Dakota
127 Mt. Carmel
128 Toonerville
137 Deer Trail
140 Punkin Center
145 Badger Mtn
147 Zap
154 Bailey
164 Chevron
263 Round Mtn (Rose Ridge)
272 Coonskin
313 Buckhorn Mtn
314 Greeley North
315 Point of Rocks
323 Bull Mountain
326 Greeley 35th
352 Prospect Mtn
359 Drake
360 PVH Fort Collins
361 Bald Mtn
362 Horsetooth Mtn
363 Loveland
Still in the middle of no where
#8
-Mike
I am only seeing sites 101, 102, 103, 104, 105, 106, 107, 108, 110 and 111 in the DB that are not re banded and I do believe that these will be re banded in the coming weeks
jimmnn
Colorado
#12
You might want to refer to the rebanding sticky thread which we update daily, all DTRS sites are re banded statewide except for the following which will occur over the next two weeks.
T0101 868.2375 Littleton (Admin) 101
T010A 868.2500 Franktown 110
T0103 868.5250 Silver Heights (Castle Rock) 103
T0108 868.7750 Lookout Mtn (Golden) 108
T0106 868.8500 Squaw Mountain (Clear Creek County) 106
T0107 868.8750 Smoky Hill (Centennial East) 107 (TODAY, underway currently)
T0102 868.9125 Riley Peak (Jefferson County) 102
T0104 868.9375 West Creek 104
T0105 868.9750 Thorodin Mtn (Wondervu) 105
Jim<
Colorado
#17
captaincraig44 said:
Aren't most (if not all) CC's rebanded to 15MHz lower than they originally were?
For the most part, yes.
When El Paso County re-banded, there were a few sites that were at 860.XXXX, and they merely dropped 1mhz. I don't know that that applies to any DTRS sites, however.
luke-1
Parker, CO
#18
For the State DTRS, yes, they all went down 15 MHz.
(The last 5 digits stay the same)
All of the associated freqs. also went down 15 MHz.
This does NOT apply to the 700MHz. sites, they remain the same.
Has anyone else noticed that this move down the spectrum, even this slight move, has seemed to improve reception? I don't notice it much just listening, but I can log sites with Pro96com now that I couldn't before.
For me here in Parker, Zap and Glendale were out of the question for logging. Now they both log fine.
I will be curious to see the effect on the northern sites. right now they are borderline for me.
Greeley, CO
#19
FWIW when they moved me to another area of the building several months ago at the daytime job I lost the ability to pick up the Bald Mtn site and had no DTRS reception at all.
Since the site has rebanded I hear it fine. Could be a case of the lower frequencies yielding better signal range.
Also to add to the discussion with the recent 700 MHz spectrum auctions it's looking like they will end up having to "reband" down the road. Remember the 700 sites are considered special temporary authorizations and are not permanent.
Phil.
DM79np
#20
Phil.
The D block for wideband public safety did not get a big enough bid. Therefore, there is now no one to foot the bill for rebanding. The FCC is probably going to lower the minimum and auction it off again. Until someone agrees to buy the spectrum, there is no need to move the 700 allocations and no one to pay for it either.
