Arizona Frequency Challenge - Part I
FLANO
AZ DB Administrator
SE of Tucson, AZ
Hi all :)
I've been slowly adding updates to the statewide Arizona Public Service Corporation trunking system. If you don't know normally listen to trunking, you may not have noticed that some elements that you might expect to hear on other frequencies, are actually hidden here.
For example, did you know that the Arizona Division of Emergency Management has 3 talk groups on this statewide system? It is one of their redundant radio systems that they test and would use in case of a state emergency.
Here's my frequency challenge for you. It will cost you as little as 5 minutes of listening to help out. If you spend more time monitoring, then that will increase your assistance to this challenge.
There are a couple of goals:
1) ID which frequency has a control channel on it in your neighborhood.
- - You will use the frequencies that will be provided below. If you've never listened to a Motorola trunked system before, one of the channels will have a continuos machine type sound on the frequency. It only goes away, if it changes to one of the other frequencies associated with the trunked system. It does not sound like static, but an actual "running machine" type sound.
2) ID the system site number of the control channel frequency that you are listening to on your radio.
- - In order to do this, you will need to have a scanner or radio that has been tapped so that the computer will interpret the control channel data for you. I highly recommend the Unitrunker software as it requires little work on your part, does not require any anything but a cable from the discriminator tap into the sound card of the computer. NO other hardware required :)
3) ID the talkgroups that you hear on your local system.
- - This will require that you have trunk-tracking scanner. This may require dedicated listening, that is exclusive to the local system. This will help to ID talkgroups that may be heard statewide. If you are in the southern part of the state, you will want to be sure that you've set your scanner to monitor the system as a "Splinter" system.
I'll be happy to be the "goto" person on this. I am getting very familiar with 4 different tower locations.
Please help contribute to this challenge. Even if you only want to help under goal number 1, it will help us to correct/update the data on this system.
- Please report which frequency that you are hearing.
- Please report which tower location you think you are hearing, if you are not using Unitrunker or some type of computer software which ID's the transmitting towers "site number".
- If you can ID the tower location, please state that it is a positive ID.
- Please report any associated frequencies that you notice with this control channel, whether it be via your scanner or a trunk tracking computer software.
- Only report the frequencies associated to the same control channel.
- Please report any Talk Groups that you run across on each site. Even if you can't ID who was on the Talk Group, this will help in determining on which sites these Talk Groups will be heard.
I will then assimilate all of your wonderful input and get this over to the system admin for inclusion into the APS Trunk System.
The frequencies will be in a follow-on post right after this one..
Thanks for your help.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Frequency Transmittter Tower Location City County
855.1125 Greens Peak 16 mi ENE McNary Apache
856.2875 Greens Peak 16 mi ENE McNary Apache
857.2875 Greens Peak 16 mi ENE McNary Apache
858.2875 Greens Peak 16 mi ENE McNary Apache
856.4125 Roof Butte 26 mi NE Chinley Apache
857.4125 Roof Butte 26 mi NE Chinley Apache
858.4125 Roof Butte 26 mi NE Chinley Apache
856.2750 Mule Mountain 3.5 mi NW Bisbee Cochise
859.2750 Mule Mountain 3.5 mi NW Bisbee Cochise
860.2750 Mule Mountain 3.5 mi NW Bisbee Cochise
861.4500 Mule Mountain 3.5 mi NW Bisbee Cochise
862.4500 Mule Mountain 3.5 mi NW Bisbee Cochise
863.4500 Mule Mountain 3.5 mi NW Bisbee Cochise
864.4500 Mule Mountain 3.5 mi NW Bisbee Cochise
865.4500 Mule Mountain 3.5 mi NW Bisbee Cochise
856.4125 17.8 mi SSW of Page Coconino
857.4125 17.8 mi SSW of Page Coconino
858.4125 17.8 mi SSW of Page Coconino
855.1125 5 mile point, 1.7 NNW Strawberry Coconino
856.8875 5 mile point, 1.7 NNW Strawberry Coconino
857.8875 5 mile point, 1.7 NNW Strawberry Coconino
858.8875 5 mile point, 1.7 NNW Strawberry Coconino
856.2875 Bill Williams 6.1 km SSW Williams Coconino
857.2875 Bill Williams 6.1 km SSW Williams Coconino
858.2875 Bill Williams 6.1 km SSW Williams Coconino
859.2875 Bill Williams 6.1 km SSW Williams Coconino
860.2875 Bill Williams 6.1 km SSW Williams Coconino
855.1125 Mount Elden 3 mi NE Flagstaff Coconino
855.6375 Mount Elden 3 mi NE Flagstaff Coconino
855.9375 Mount Elden 3 mi NE Flagstaff Coconino
856.3125 Mount Elden 3 mi NE Flagstaff Coconino
856.8875 Mount Elden 3 mi NE Flagstaff Coconino
857.8875 Mount Elden 3 mi NE Flagstaff Coconino
858.3375 Mount Elden 3 mi NE Flagstaff Coconino
858.8875 Mount Elden 3 mi NE Flagstaff Coconino
859.3125 Mount Elden 3 mi NE Flagstaff Coconino
859.3375 Mount Elden 3 mi NE Flagstaff Coconino
859.8875 Mount Elden 3 mi NE Flagstaff Coconino
860.3125 Mount Elden 3 mi NE Flagstaff Coconino
860.3375 Mount Elden 3 mi NE Flagstaff Coconino
860.8875 Mount Elden 3 mi NE Flagstaff Coconino
868.3125 Mount Elden 3 mi NE Flagstaff Coconino
855.9375 Diamond Point 9 mi ENE Payson Gila
856.4125 Diamond Point 9 mi ENE Payson Gila
857.4125 Diamond Point 9 mi ENE Payson Gila
858.3375 Diamond Point 9 mi ENE Payson Gila
858.4125 Diamond Point 9 mi ENE Payson Gila
859.3375 Diamond Point 9 mi ENE Payson Gila
859.4125 Diamond Point 9 mi ENE Payson Gila
860.3375 Diamond Point 9 mi ENE Payson Gila
860.4125 Diamond Point 9 mi ENE Payson Gila
856.2875 Mount Ord 4.5 mi NE Sunflower Gila
857.2875 Mount Ord 4.5 mi NE Sunflower Gila
858.2875 Mount Ord 4.5 mi NE Sunflower Gila
859.2875 Mount Ord 4.5 mi NE Sunflower Gila
860.2875 Mount Ord 4.5 mi NE Sunflower Gila
855.1125 Signal Peak Globe Gila
855.9375 Signal Peak Globe Gila
856.4125 Signal Peak Globe Gila
857.2875 Signal Peak Globe Gila
857.4125 Signal Peak Globe Gila
858.2875 Signal Peak Globe Gila
858.3375 Signal Peak Globe Gila
858.4125 Signal Peak Globe Gila
859.2875 Signal Peak Globe Gila
859.3375 Signal Peak Globe Gila
859.4125 Signal Peak Globe Gila
860.2875 Signal Peak Globe Gila
860.3375 Signal Peak Globe Gila
860.4125 Signal Peak Globe Gila
857.2875 Black Peak 5.1 mi SE Parker La Paz
858.2875 Black Peak 5.1 mi SE Parker La Paz
858.3375 Black Peak 5.1 mi SE Parker La Paz
859.2875 Black Peak 5.1 mi SE Parker La Paz
859.3375 Black Peak 5.1 mi SE Parker La Paz
860.2875 Black Peak 5.1 mi SE Parker La Paz
860.3375 Black Peak 5.1 mi SE Parker La Paz
856.2750 Cunningham Mountain Quartzsite La Paz
865.4500 Cunningham Mountain Quartzsite La Paz
855.1125 Oatman Mountain Gila Bend Maricopa
856.8625 Oatman Mountain Gila Bend Maricopa
857.4125 Oatman Mountain Gila Bend Maricopa
858.4125 Oatman Mountain Gila Bend Maricopa
854.9125 Palo Verde Nuc Gen Stn Wintersburg Maricopa
855.3215 Palo Verde Nuc Gen Stn Wintersburg Maricopa
856.8875 Palo Verde Nuc Gen Stn Wintersburg Maricopa
857.8875 Palo Verde Nuc Gen Stn Wintersburg Maricopa
858.8875 Palo Verde Nuc Gen Stn Wintersburg Maricopa
859.8875 Palo Verde Nuc Gen Stn Wintersburg Maricopa
860.8875 Palo Verde Nuc Gen Stn Wintersburg Maricopa
855.1125 Shaw Butte Phoenix Maricopa
855.3875 Shaw Butte Phoenix Maricopa
855.6375 Shaw Butte Phoenix Maricopa
855.9375 Shaw Butte Phoenix Maricopa
856.8875 Shaw Butte Phoenix Maricopa
857.8875 Shaw Butte Phoenix Maricopa
858.3375 Shaw Butte Phoenix Maricopa
858.8875 Shaw Butte Phoenix Maricopa
859.3375 Shaw Butte Phoenix Maricopa
859.8875 Shaw Butte Phoenix Maricopa
860.3375 Shaw Butte Phoenix Maricopa
860.8875 Shaw Butte Phoenix Maricopa
855.9375 Smith Peak Aguila Maricopa
856.4125 Smith Peak Aguila Maricopa
857.4125 Smith Peak Aguila Maricopa
858.3375 Smith Peak Aguila Maricopa
858.4125 Smith Peak Aguila Maricopa
859.3375 Smith Peak Aguila Maricopa
859.4125 Smith Peak Aguila Maricopa
860.3375 Smith Peak Aguila Maricopa
860.4125 Smith Peak Aguila Maricopa
855.1125 Thompson Peak Phoenix Maricopa
855.3875 Thompson Peak Phoenix Maricopa
855.6375 Thompson Peak Phoenix Maricopa
855.9375 Thompson Peak Phoenix Maricopa
856.8875 Thompson Peak Scottsdale Maricopa
857.8875 Thompson Peak Scottsdale Maricopa
858.3375 Thompson Peak Phoenix Maricopa
858.8875 Thompson Peak Scottsdale Maricopa
859.3375 Thompson Peak Phoenix Maricopa
859.8875 Thompson Peak Scottsdale Maricopa
860.3375 Thompson Peak Phoenix Maricopa
860.8875 Thompson Peak Scottsdale Maricopa
855.1125 White Tanks Mountain Phoenix Maricopa
855.3875 White Tanks Mountain Phoenix Maricopa
855.6375 White Tanks Mountain Phoenix Maricopa
855.9375 White Tanks Mountain Phoenix Maricopa
858.3375 White Tanks Mountain Phoenix Maricopa
859.3375 White Tanks Mountain Phoenix Maricopa
860.3375 White Tanks Mountain Phoenix Maricopa
858.3375 Deza Bluff ES 4 mi N Tohatchi Mckinley, NM
859.3375 Deza Bluff ES 4 mi N Tohatchi Mckinley, NM
860.3375 Deza Bluff ES 4 mi N Tohatchi Mckinley, NM
855.1125 Hualapai Mountain 15 mi SE Kingman Mohave
858.3375 Hualapai Mountain 15 mi SE Kingman Mohave
859.3375 Hualapai Mountain 15 mi SE Kingman Mohave
860.3375 Hualapai Mountain 15 mi SE Kingman Mohave
856.8875 Brookbank 11.2 mi SW Heber Navajo
857.8875 Brookbank 11.2 mi SW Heber Navajo
858.8875 Brookbank 11.2 mi SW Heber Navajo
856.4125 Dry Lake 17 mi NNW Snowflake Navajo
857.4125 Dry Lake 17 mi NNW Snowflake Navajo
858.4125 Dry Lake 17 mi NNW Snowflake Navajo
858.3375 Preston Mesa 16 mi N Tuba City Navajo
859.3375 Preston Mesa 16 mi N Tuba City Navajo
860.3375 Preston Mesa 16 mi N Tuba City Navajo
856.2750 Childs Mountain Ajo Pima
857.2750 Childs Mountain Ajo Pima
859.2750 Childs Mountain Ajo Pima
860.2750 Childs Mountain Ajo Pima
854.9125 Mount Lemmon 2 km W Summerhaven Pima
855.1125 Mount Lemmon 2 km W Summerhaven Pima
855.3875 Mount Lemmon 2 km W Summerhaven Pima
855.6375 Mount Lemmon 2 km W Summerhaven Pima
855.9375 Mount Lemmon 2 km W Summerhaven Pima
861.4500 Mount Lemmon 2 km W Summerhaven Pima
862.4500 Mount Lemmon 2 km W Summerhaven Pima
863.4500 Mount Lemmon 2 km W Summerhaven Pima
864.4500 Mount Lemmon 2 km W Summerhaven Pima
865.4500 Mount Lemmon 2 km W Summerhaven Pima
856.8875 Sacaton Peak 8.5 mi NW Coolidge Pinal
857.8875 Sacaton Peak 8.5 mi NW Coolidge Pinal
858.8875 Sacaton Peak 8.5 mi NW Coolidge Pinal
859.8875 Sacaton Peak 8.5 mi NW Coolidge Pinal
860.8875 Sacaton Peak 8.5 mi NW Coolidge Pinal
855.1125 Juniper Mountain 14 mi WSW Selgiman Yavapai
856.8875 Juniper Mountain 14 mi WSW Selgiman Yavapai
857.8875 Juniper Mountain 14 mi WSW Selgiman Yavapai
858.8875 Juniper Mountain 14 mi WSW Selgiman Yavapai
856.4125 McCloud Mountains 2.7 mi WNW Hillside Yavapai
856.8875 McCloud Mountains 2.7 mi WNW Hillside Yavapai
857.4125 McCloud Mountains 2.7 mi WNW Hillside Yavapai
857.8875 McCloud Mountains 2.7 mi WNW Hillside Yavapai
858.4125 McCloud Mountains 2.7 mi WNW Hillside Yavapai
858.8875 McCloud Mountains 2.7 mi WNW Hillside Yavapai
859.8875 McCloud Mountains 2.7 mi WNW Hillside Yavapai
860.8875 McCloud Mountains 2.7 mi WNW Hillside Yavapai
856.2875 Mingus Mountain Jerome Yavapai
856.4125 Mingus Mountain Jerome Yavapai
857.2875 Mingus Mountain Jerome Yavapai
857.4125 Mingus Mountain Jerome Yavapai
858.2875 Mingus Mountain Jerome Yavapai
858.4125 Mingus Mountain Jerome Yavapai
859.2875 Mingus Mountain Jerome Yavapai
859.4125 Mingus Mountain Jerome Yavapai
860.2875 Mingus Mountain Jerome Yavapai
860.4125 Mingus Mountain Jerome Yavapai
855.9375 Mount Francis 6 mi SW Prescott Yavapai
858.3375 Mount Francis 6 mi SW Prescott Yavapai
859.3375 Mount Francis 6 mi SW Prescott Yavapai
860.3375 Mount Francis 6 mi SW Prescott Yavapai
856.3125 Towers Mountain 2.6 mi NW Crown King Yavapai
858.3125 Towers Mountain 2.6 mi NW Crown King Yavapai
859.3125 Towers Mountain 2.6 mi NW Crown King Yavapai
860.3125 Towers Mountain 2.6 mi NW Crown King Yavapai
FLANO
AZ DB Administrator
SE of Tucson, AZ
And finally :)
856.2750 Telegraph Pass 16 mi E Yuma Yuma
861.4500 Telegraph Pass 16 mi E Yuma Yuma
862.4500 Telegraph Pass 16 mi E Yuma Yuma
863.4500 Telegraph Pass 16 mi E Yuma Yuma
864.4500 Telegraph Pass 16 mi E Yuma Yuma
865.4500 Telegraph Pass 16 mi E Yuma Yuma
861.4500 Yucca Power Plant Yuma Yuma
862.4500 Yucca Power Plant Yuma Yuma
863.4500 Yucca Power Plant Yuma Yuma
864.4500 Yucca Power Plant Yuma Yuma
865.4500 Yucca Power Plant Yuma Yuma
ctrl
Phoenix Area.
I am un-sure of the site which I am recieving on this frequency (860.3375):
----- SID: 5C1Dh-0001 -- Talk group ID: 4848 (Unknown)
I am 75% positive I am recieving Towers mountain on (860.3125):
----- SID: 5C1Dh-0025 -- Talk group ID: 4848 (Unknown)
Looks like these are already in the database, probably no help here.
I'll try some more later, I have my doubts that anymore will work here on the westside in peoria.
Hopefully some more people will jump on these and find more..
Just a reminder to those folks running UniTrunker ...
Most networked systems announce (1) backup control channels for the currently monitored site and also (2) the control channels of neighboring sites. To see a list of neighbor sites use the [V]iew -> Ste to see if any adjacent sites have been found. To see the control channels of these neighbor sites you can use the [C]hannel view.
-rick
FLANO
AZ DB Administrator
SE of Tucson, AZ
Great! That's one of the frequencies that I was able to monitor for a little while last night from my location, to the southeast of Tucson. TG 4848 seems to have a lot of activity on it with "Operations" and the field guys for APS. Hopefully you might hear which "Operations" it is. As far as figuring out the site, if you're just using your scanner, be sure to notate what frequencies your scanner is moving to, when the scanner follows the conversation. That'll help provide a clue on which site it might be.
Thanks,
FLANO
AZ DB Administrator
SE of Tucson, AZ
You should be able to hear 864.45mhz. That one is located on Mt Lemmon. You might also be able to hear 855.9375mhz.
Also, try the 860.3375mhz tonight. That one is from the Phoenix area, but unsure which site.
See if any of those work for you...
Astrak said:
Uhhhhhhhh none of those freqs work for me here in Marana.
laser21012
Gold Canyon, AZ
I will be traveling to Gold Canyon (near Apache Junction) tomorrow for about 3 weeks. In previous visits I have had trouble understanding the way the statewide system is set up. I am not sure which location would be the closest for to me to monitor. I do have a scanner that has a discriminator tap on it . I use Trunker software on my computer to decode the datastream. If you could tell me what frequencies to monitor, I would be glad to monitor them and see if I can help.
Bob
EricCottrell
Boston, Ma
Bob
Hello,
As an experienced trunked radio DXer let me throw in my two cents.
You never know what signals you can pickup so I search the 800 band (851.000 to 868.9875 with a 12.5 KHz step) looking for control channels. I can usually recognize Motorola, EDACS, or P25 control channels by how they sound. The different types of Motorola systems sound slightly different and it is almost to the point where I can determine if the system is a Type 1, Type 2, or Smartzone by listening to the idle pattern of the system. I can usually tell when a voice frequency is active because the pattern changes. I am sure there are Motorola Smartzone systems around your home QTH that you can listen to get a feel for what they sound like.
With trunker you may need to go into the options menu, change Neighbors to display on the screen, and restart the program. The frequencies displayed gives you nearby sites to try.
You can also get useful information from a Pro96, 396T, or 996T although not as complete as using the various versions of trunker. Some recent scanners will display the site id as well as the sysid.
I am going to Az at the end of September so I will be scanning this system as well.
73 Eric
FLANO
AZ DB Administrator
SE of Tucson, AZ
Bob
Hi Bob,
Thanks for helping out. Apache Junction would put within listenin range the towers within Maricopa County, Pinal County, and Gila County.
If you go to message number 2 of this thread, you need to the last entry on the line to determine the counties listed above. Some counties have multiple tower locations, so be sure to notate the differences. In that area, there will be some systems with similar frequencies assigned, so it's going to take some detective work. If your bringing Trunker that will be a plus.
I'd be interested in all TG's that you hit on, even if there is no audible activity. One thing I've noticed with this system, using Unitrunker software, these guys like to play with their radios. They tune through the different channel settings. Does Trunker also allow export of Radio ID's. I have a number of them that I've collected over the past year plus. I would like to correlate them if possible too....
Thanks again and happy hunting,
John
SE of Tucson
FLANO
AZ DB Administrator
SE of Tucson, AZ
EricCottrell said:
Hello,
...... edited
73 Eric
Hi Eric,
Very nice input about recognizing the control channels. I look forward to hearing from you when you get out here. Hopefully by then, will have a much bigger database going that will give you something to chase after :)
Thanks,
John
FLANO
AZ DB Administrator
SE of Tucson, AZ
A little more information about the APS system for everyone. It's obviously statewide, but we have mega holes in it. It is NOT only used by the Power people. While most traffic is from these guys, there is other non-power related traffic hidden in there. That's why I'm trying to bring awareness to this very promising system.
I am heading up to Flagstaff this Friday to Sunday. I'm a vendor at the Celtic Festival up there, but I will be bringing my radios and computer to put it to work while driving up there, to hit some systems from the Tucson area and up as I drive by, as well as, take a look at the Flagstaff area.
Thanks for all your help,
STiMULi
Tucson, Arizona
How is the project going?
I haven't been mobile and been able to take a look at/store the IDs at the same time.
I will soon have an excellent antenna up to assist in some area research using a directional Yagi.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Well, it is moving slowly, but I have received some inputs from mostly in the Phoenix area. I am compiliing the data and, as soon as I get something tangible, I update the APS trunk website. I can tell you that some have begun using some software and have discovered what I already know....it is not only used by the APS folks.
I just returned from Flagstaff. Not too active up there, but I was able to confirm a couple of things, and will post them, once I do a data dump from my laptop. Might be posted by this weekend, as I have a busy schedule :<
Thanks to everyone who has contributed privately and publicly.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Hello All,
Special thanks to everyone taking the time to listen or help ID the TG's and users on the APS trunking system in Arizona.
To date, 94 different TG's have been "seen". Most are not ID'd. Any help on the TG ID's, even if all you can say is that it is related to the APS folks, helps. As you can see though, not everyone on the system is an "APS" player.
Here's the update of users and TG's as of today, 21 July 06:
TG ID Area
48
176
368 Emergency Activity
944
976 AZ Fraudulent ID Task Force (AFIT) Statewide
1008 AFIT Statewide
1040 AFIT F1 Statewide
1072 AFIT Statewide
1168 AZ Div of Emergency Mgmt (DEMA) F1 Statewide
1200 AZ DEMA F2 Statewide
1648
1680 AZ Inter-Agency Statewide
2000 Possibly Data
3248
3255
3280
3312
3344
3408
3440
3472 Four Corners
3504
3536
3600
3632
4800
4816
4818
4848
4851
4880
4883
5936
6400
6416
6448
6487
6512
7552
8048 Valley Parts Phoenix
8192
8208
8224
8336
8608
9648
9680
9712
9744 APS Field Ops Phoenix
9808
9840
9872 APS Field Ops
9904
9936 Forestry
10448
10640
10960
11376
11408
11415
12320
12816
12819
12848
12880
12912
12944
12976
20560
23568
24080 APS Field Ops Flagstaff
24176
24208 APS Field Ops Snowflake
25072
25680 Dispatch-Outage Flagstaff
25808 COTTONWOOD Office Cottonwood
27248
27280 APS Field Ops Casa Grande
27312 DOUGLAS Office Related Srn Arizona
27376 DOUGLAS Office Srn Arizona
27440 GLOBE Office Globe
28848 YUMA Office Yuma
28851
28880 Cross-patched with 28848 Yuma
28912
28976 APS Field Ops Yuma
35408
36096
41616
45728
48096
51328
58896
64544
Frequencies that have been identified so far. Most locations have not been ID'd, and some locations are tentative for now.
Site LCN Control Frequency Frequency Tentative ID
1 175 NO 855.3875 Scottsdale
1 185 NO 855.6375 Scottsdale
1 197 NO 855.9375 Scottsdale
1 296 YES 858.4125 Scottsdale
1 333 YES 859.3375 Scottsdale
1 373 YES 860.3375 Scottsdale
2 296 YES 858.4125 Site 2
6 296 YES 858.4125 Site 6
9 197 YES 855.9375 Sacaton Peak
9 315 YES 858.8875 Sacaton Peak
10 197 YES 855.9250 Mt Lemmon
10 331 YES 859.2750 Mt Lemmon
10 498 YES 863.4500 Mt Lemmon
10 538 YES 864.4500 Mt Lemmon
11 185 YES 855.6375 Site 11
11 197 YES 855.9375 Site 11
11 256 YES 857.4125 Site 11
11 296 YES 858.4125 Site 11
12 291 YES 858.2875 Site 12
13 331 YES 859.2750 Bisbee
13 538 YES 864.4500 Bisbee
14 212 NO 856.3125 Mt Elden
14 292 NO 858.3125 Mt Elden
14 332 YES 859.3125 Mt Elden
14 372 YES 860.3125 Mt Elden
15 296 YES 858.4125 Site 15/Nrn AZ
18 291 YES 858.2875 Site 18/Nrn AZ
20 315 YES 858.8875 Site 20/Nrn AZ
23 291 YES 858.2875 Site 23/Nrn AZ
24 373 YES 860.3375 Site 24/Nrn AZ
25 372 YES 860.3125 Towers Mountain
27 46 NO 852.1625 Prob Mt Lemmon
27 156 NO 854.9125 Prob Mt Lemmon
27 175 NO 855.3875 Prob Mt Lemmon
27 185 YES 855.6375 Prob Mt Lemmon
27 197 YES 855.9375 Prob Mt Lemmon
27 296 YES 858.4125 Prob Mt Lemmon
27 315 YES 858.8875 Prob Mt Lemmon
27 344 NO 859.6125 Prob Mt Lemmon
27 373 YES 860.3375 Prob Mt Lemmon
27 498 NO 863.4625 Prob Mt Lemmon
27 538 YES 864.4625 Prob Mt Lemmon
27 958 NO 868.9750 Prob Mt Lemmon
28 296 YES 858.4125 Site 28/Nrn AZ
31 296 YES 858.4125 Site 31/Nrn AZ
On my recent trip to Flagstaff, I heard the following APS Trunk control channels active. Unfortunately, computer was down, so unable to provide the site ID's, but I did write down approximately where I began to hear the control channel, for those who live in the area and can hopefully check it out and ID.
855.9375mhz - I-10, Exit 161
858.4125mhz - I-10, Exit 161
858.4125mhz - I-17, Exit 252
860.3125mhz - I-17, Exit 253
Thanks,
FLANO
AZ DB Administrator
SE of Tucson, AZ
ctrl said:
60208
60912
Two more I have logged that dont appear on your list. (on 860.3375)
Thanks I'll add them to the growing list !
Any idea who is using those TG's? APS or other?
radioprescott
East Central Arizona
Yavapai County
I recently heard TG 1008 surveillance traffic late one weekend evening. Locations given were Phoenix - I was hearng them on Mingus.
Also it appears that Prescott traffic on Mt Francis and Mingus are simulcast most of the time.
hulka
Metro Phoenix area
860.3375 CC 5C1D is the ID I am gettingon the display on the '96.
I am using a Pro-96, that is it. Hope this helps a little. I will be listening some to see what I hear.
Kevin
