Armstrong County Pa
Theo1961
North Apollo, PA
Hello All, I have been trying to program Barker Transportation on my TRX 2. I haven’t noticed anywhere that it is encrypted in anyway. I am well within a reasonable distance. Can’t figure it out. Oh and they are a school bus company serving Armstrong School District
tvengr
Well Known Member
Baltimore County, MD
Are you trying the 464.125 frequency in the database? That frequency is licensed for NFM, DMR, and NXDN. Do you hear anything? Check your squelch setting.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
It would help if you stated which frequency(ies) or system(s) you tried and when you started listening. Certainly not 4:50am on a Monday morning when you opened this thread. The analog 464.125 entry may be deprecated
The NXDN system below is licensed to Barker (it includes same callsign as listed analog entry). Have you tried here? No talkgroups were submitted so you'll need to listen via group wildcard ID to confirm or negate encryption. Remember to update the database with talkgroup(s) if you find activity here
bearcat
Here is what is what is available so far for Barker
NXDN - Trunked
Talkgroups
Air Ride Base-3
Air Ride Cars-4
Barker Bus Base A Armstrong County Scool District-5
Buses A Armstrong County School District-6
Bus Maintenance-7
Freq LCN
452.400000 1
464.125000 2
463.450000 3
Theo1961
North Apollo, PA
NXDN - Trunked
Talkgroups
Air Ride Base-3
Air Ride Cars-4
Bus Maintenance-7
Freq LCN
452.400000 1
464.125000 2
463.450000 3
Thank you so much. Under Talk Groups is the info shown get entered under talk groups?
Theo1961
North Apollo, PA
NXDN - Trunked
Talkgroups
Air Ride Base-3
Air Ride Cars-4
Bus Maintenance-7
Freq LCN
452.400000 1
464.125000 2
463.450000 3
I’m not real familiar with programming s Trunked System manually but until my new computer gets here, I have no choice. Does the Freq. LCN get entered where it asks for the Rafio ID?
bearcat
No Radio ID is the digital no. assigned to each radio. Freq and LCN goes in the Site info Also select NXDN Trunk for this system
hundeesport412
Natrona Heights, Pennsylvania
Where do I find that UID number?
That is the UID of the radio. It could be the same as what is marked on the vehicle or not. Playing the recordings, they used Names not numbers. I am seeing the UID number because I'm using PROSCAN . I have my scanner set to display the UID. I only had approx 20 hits today. I will monitor tomorrow also and we will see what happens. This screen shot has the Talk Groups. I have never programmed a TRX 2 but maybe someone else could help out.
bearcat
bearcat
Not sure where you gout those Talk Groups as the Data base does not have any listed. If you are able to submit those to Data base that would be great.
I did not submit them as they could be very dated. I would like a more firm confirmation prior to submitting.
