Astro Saber Won't Receive Digital
stevez97
Myrtle Beach, South Carolina
Just programmed up for the first time. It receives analog just fine. When I attempt to choose "DIgital CSQ" under the "Rx Unmute Rule" I get an error message. I presume this is why I am not able to receive the digital frequency.
Is this a flash code issue? I thought the flash code indicated P25 digital capability.
Can someone point me in the right direction?
Thanks!
kc2shw
astro wont receive
you may want to check to see if you actually have a digital radio, go into service and check your flash, your radio may be astro ready and actually astro or digital. if the radio is digital what version are you using?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
A couple of things to check through the service mode:
1) What's the flash code of the radio
2) What's the Dsp version and firmware versions?
then,
3) Whats the error message you receive.
VSELP radios will not do Digital Squelch. I'm not even sure a VSELP radio will give you that choice.
Colby, Digital CSQ is a valid receive unmute rule for P25 radios. It's the digital equivalent of carrier squelch on analog. Great when you don't know the NAC.
If you do known the NAC, then you can use Normal Squelch.
bezking
On the Road
Um, yes it is. Digital CSQ and DCS are two different things. You are thinking of Digital-Coded Squelch, a feature of most analog radios. Digital CSQ is a feature implemented on P25 radios.
According the the EFJohnson help files:
Digital Squelch - When checked, carrier squelch is enabled which results in all digital traffic, regardless of NAC or talk group ID, being received. This does not program NAC F7E which is used the same as other NAC codes.
Ah, you beat me to it, Mike... :D
stevez97
Thanks for the replies. The world of /\/\ digital is new to me.
In any event, I found the following:
Model: H04SDF9PW7AN
Firmware: 03.33.00.00
DSP Software: 105.01.04
Flashcode: 800001-000000-2
Hmmmmm.............I have a funny feeling this is a analog only radio?????
sfd119
Your flashcode breaks down to:
H15/H44 H15 is Astro Data / H44 is VRM500 for MCS2000 only
H35/G48 Conventional Operation
AKA it does not look good.
bezking
On the Road
For an AS that is totally invalid. The first bit is totally wrong and the second one is Conventional only.
Correct me if I am wrong, but I believe that 8 means it's a VSELP radio...
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Judging by the dsp rev, it's a vselp radio.
Only p25 radios can do digital squelch.
FFPM571
Nashvillle
let me guess Astro Saber II probably engraved on the front with a P and a 3-4 digit number and possibly a pd name. If its what I am thinkng its is an former DC PD radio. I have the same one and its VSLEP 512k . If someone told you it was digital they were hosing you.
