ASTRO Software question
Victor69
Barry County Michigan
Hello All, I was wondering if anyone knows if RSS for Astro Spectra Ver, 2.05.00 would also program a Astro Saber with Ver. 2.02.00. in it? Thanks
rescue161
KE4FHH
Hubert, NC
There is a mobile version and a portable version. It depends on which one you have as their revisions are typically the same. You have to look at the actual part number of the CPS/RSS.
kb9sxk
Southern Indiana
Astro Saber / XTS 3000 CPS is one and the same, and will only do those 2 radios.
Dunno about the RSS, but i doubt it.
rescue161
KE4FHH
Hubert, NC
RSS is the same as CPS. The portable CPS/RSS will not program a mobile and the mobile CPS/RSS will not program a portable. If you bought the combined CPS/RSS package, they will do both, but it just installs both as seperate packages.
You have to check which part number of CPS/RSS you have.
Josh
Wyandotte Michigan
The firmware in the radio doesn't matter at all if the radio was programmed with a newer version of RSS than you have.
The last version of RSS was R9.05, from 2002.
CPS (Windows based) replaced RSS shortly thereafter and the current version is somewhere around R5.xx.xx.
-Josh
AlexC
NY/NJ Metro Area
Don't forget that I believe up until version 3 of the CPS was backwards compatable with RSS 9.5. So you could change something in CPS, read the radio with RSS and change another thing.
But there are two separate packages - 1 for mobiles and 1 for portables as others have stated.
Best advice would be to buy a subscription, and get version 5.x
-Alex
Scooty
Hello,
Can anyone tell me where I can get an Astro Saber XTS 3000 CPS Manual?
