Astro Spectra bandsplit problem
W5SGS
Bander,Tx
I got a astro spectra uhf p25 mobile. It decodes as a 437-482 mhz bandsplit. D04RKF9PW5ANSP01 Flashcode 1000010000007. It even shows this on the CPS. BUT it only will program 453-490MHZ witch is not a valid bandsplit for the astro spectra. Anyone ever had this issue before?
Project25_MASTR
Millennial Graying OBT Guy
Texas
Have you tried aligning it? Another suggestion would be to pull the covers and actually check board numbers.
Secondly I'm going to point out it's a Special Purpose radio so it may have been built to order for a specific split.
W5SGS
Bander,Tx
Bandsplit problem
I do not have any of the equpment to preform an allignment on it anymore. I think it was just built that way.. Ill prolly try to hex edit it and see if i can get it working. It tx and rx fine on analog and p25
FFPM571
Nashvillle
the SP01 is a special production If its a bunch of radios that came out of Southern California it was set up from Motorola because they use the high end of the UHF T band above 450 up to 490
N4KVE
PALM BEACH, FLORIDA
This is called an "oxymoron". The most popular split was 450-482. However some special departments needed to go higher, so a special 453-490 split was made. But 438-470 was it's own separate split, made mostly as motorcycle radios. So there is no 437-482 split radio. It's either 438-470, 450-482, or 453-490. Open the radio, look at the modules, & then go to repeater builder.com to see what you really have.
