Astro Spectra recap services?
tetto
Is anyone around here still doing Spectra recaps? I know cmdrwill was the go-to guy but he hasn't been active since 2021.
bhamwildcat
I bought a NOS regular Spectra from feebay and I want to find someone to do this as well. I tried to power it on, and it was acting like it didn't get enough voltage. Decided it would be best to not try anything else until I was positive I wasn't destroying it inadvertently. If anyone knows anyone or anywhere I can get this done I would appreciate it.
tetto
I had no leads so I decided to give it a go myself. While I've done plenty of hobby soldering here and there over the years, quickly realized I didn't have the skills for this (SMDs). I got 3 caps replaced (poorly) then decided to stop before I caused damage.
a417
Smart idea, don't want to kill your investment.
hot air or iron?
tetto
hot air or iron?
Both. I'm comfortable with an iron but the bulk of the contact surface and pads are underneath the caps, so an iron only gets a fraction of the area heated with the cap in place.
I got a hot air rework gun specifically for this but after much practice and watching tutorials, that's when I realized I lack the skill.
arlo
I use caps with leads and let them stand up a little. Radio works fine. Looks like of ugly, but with covers on all ok.
I have heated tweezers for my pace and can remove old caps easy.
a417
(y)
If the radio is going to be a shelf queen, this should be fine. This wouldn't be such a hot idea if you were mobile mounting it.
tetto
(y)
OMG I'm an idiot. I hadn't even considered a different style capacitor.
What caps would you guys recommended if it it going to be mobile mounted? In a vehicle that goes off road in mountainous terrain for fire fighting - not extremely rough but up there. I know you can put some hot glue in to support it too. Not sure how warm these caps get, though.
a417
Welp...I'd recommend like-for-like in that situation, or at least with modern equivalents from a reputable manufacturer.
Now that you've explained your work scope for this radio, I'd advise against home-jobbing it due to it being used in a life-safety situation. We are talking about radios that easily qualify for antique license plates in many states. I'd replace them with something more modern, rather than try to learn on something that will likely fail when you need it the most.
'hic sunt dracones'
marcotor
I ♥ÆS Ø
Sunny SoCal
Uncle Will as we affectionally called him, has left this earth. He was a fun guy and a whiz with those Spectras.
N4KVE
PALM BEACH, FLORIDA
Didn’t know. He recapped a few for me, and he did the preamp mod on one of them. Later on, he fixed a RIB for me. He sure knew his stuff. Still have his phone #, & E-Mail addy in my phone. Echocomms@*****.com. RIP Will.
arlo
Another way to replace the capacitors. Use micro flush cutters and nibble and dissect the capacitor bodies leaving the leads. Use soldering pencil to remove the the exposed leads. Use Q-tips and flux cleaner to remove the capacitor leakage. Use radial lead new capacitors, clip the legs short as possible and solder to the pads. Get polarity correct.
Anderegg
Enter text in this field
San Diego
Could always check the yellow pages for a stereo VCR or TV repair shop locally...I am sure they would be dying to solder things, and you might help them make rent or avoid bankrupcy for another week.
Paul
ElroyJetson
At this point anything relating to an Astro radio is radio archaeology and you'll probably end up having to learn to do it yourself. Those who would do it 15 years ago have all retired or don't want to mess with it anymore.
a417
I saw that post by Mary in the moto groups.io couple of days ago, quite sad for all involved.
