ASTRO Spectra Split PL Tones
KK4LQX
Suffolk, VA
Is the ASTRO Spectra capable of using a different PL one for RX than it is for TX.
I have a local amateur radio repeater system with a remote receive site. I need to TX on with a PL of 162.2 to get into the remote receiver but I need to RX with a PL tone of 156.7 to hear the transmitter. I can hear the transmitter just fine with MONITOR ON. Turn it to MONITOR OFF and the busy light stays on but the speaker goes quiet.
I am also experiencing this when on the correct channel to transmit and listen directly to the repeater, not through a remote receive site. In other words i'm listening and talking on a repeater that listens for and transmits with a PL tone of 156.7.
What's even more confusing is that there is another repeater near by that I have programmed in the EXACT same way (with the exception of proper frequency and tones) and it works great!
I have set up my Kenwood D710, V71 and D72 to use CTCSS when listening on the main repeater channel and they work just fine I seem to only be having this issue with a ASTRO Spectra.
Is there something i'm missing or should try?
Thank you all in advance for your time and assistance.
rescue161
KE4FHH
Hubert, NC
Yes. The Astro Spectra can do split PL/DPL. You can transmit a tone (PL) / digital code (DPL) that is different than the receive tone (PL) / digital code (DPL) and vice versa.
cmdrwill
So Cali
Go to the personality and it should be on the same view as the RX and TX frequencies. Drop down boxes.
