Astro Spectra
msgmconway
Emmitsburg
Has anyone here successfully changed a Motorola Astro Spectra VHF (146-174 MHz) radio to operate on 136-162 MHz? We (a fellow Civil Air Patrol member and I) acquired a couple for these only to discover that they won't transmit on the necessary frequencies. Can the be modded or should we just resell them and look for other radios? I have the necessary software and can program the radio but get a warning message about being out of band.
Thanks in advance! 73
Mike
MTS2000des
5B2_BEE00 Czar
Start here. Note that the Astro Spectras are 30 year old radios and the VCO's may not like more than 3MHz or so before they start unlocking. No harm will come, just may not work. Usually the VHF models will work just fine down to about 144, but below that, may or may not work well.
Also, these radios are notorious for bad "pissy" electrolytic caps which cause them to first start acting weird, popping audio, then they will start throwing fail codes. They aren't too difficult to replace but if the electrolyte has leaked, the multi-layer boards may be beyond economical repair.
nhfirefighter
Also if you decide to sell, keep your eyes open for a J-split instead of K-split radio. They are out there and are factory set to the lower bands. There are even some Astro Spectra Plus models in the J split.
