Astro systems greyed out?
alphagamma
New Hampshire
Hi Folks,
Quick (probably dumb) question. I bought a spectra under the impression it was an astro spectra so I could talk/monitor p25. Well went to program it today and there is no astro systems option in the conventional list. The model # is T04KLH9PW9AN. Just confused as to why this isn't working, hopefully someone here can explain.
Arizona
What is the flash code of the radio? Have you tried to setup a astro channel under the conventional personality first? It's been awhile since I have programmed an astro spectra so I could be wrong. However not all astro spectra radios were flashed for p25.
mikewazowski
Staff member
Central Ontario
If you can read it with Astro Spectra CPS, it's an Astro Spectra.
Post your flashcode, DSP and Firmware versions.
Chances are you've got an analog only radio.
alphagamma
New Hampshire
Flashcode: 000001-002000-5
and I have unknowns for the firmware and DSP in cps so I'll try reading it again in a bit.
alphagamma
New Hampshire
Anyway to change this or is it a hardware issue?
Edit: was able to figure it out myself on P25 forums. Thanks for the help folks!
mikewazowski
Staff member
Central Ontario
You need to send it to someone to have digital added and your firmware refreshed.
You could do it yourself but the likelihood of you having an iButton, SmartRib and Flash cable are probably low.
kayfox
Let me further clarify what MikeOxlong is getting at:
By default, ASTRO radios with Analog Only operation are flashed with analog only DSP code (the version starts with an A), they therefore will not support digital operation until they are upgraded with digital DSP code (IIRC version starts with an I).
alphagamma
New Hampshire
Yeah I figure I will talk to some shops in the area and see if any of them would be willing to do it. I have everything but the iButton and I know the cost of those is pretty high. Just learning about these radios now that I have all the programming equipment and got one pretty cheap at auction. Thanks again guys
mikewazowski
Staff member
Central Ontario
Your biggest problem is going to be purchasing the flash that enables digital. Motorola doesn't support that radio anymore so purchasing the flash from them will be next to impossible.
