Astron VLS-25M board question
wcu02mpa
Asheville,NC
I have an Astro VLS-25M power supply that has fried a resistor on the board. It is the R14 resistor and I cannot find a schematic of that board. I found one for the RS-35 PS and it shows an R14 resitor to be 330 ohms in value. Can anyone assist me on this?? Either a schematic or verify what the value of that resitor is? I have called Astron, but no answers the phone.
Also the LM723 chips seem to fail and where can I get one of those if needed?
thx,
Mike
wcu02mpa
Asheville,NC
Someone picked up at Astron.......560 ohms and 1/2 watt rating. And IC can be had from digikey. Evidently this is a common problem with some Astron power supplies so just FYI if your PS show low voltage....most likely problem.
Mike
