On the advise of a friend I bought an Anytone AT-5888 to use for 2M/440/GMRS here in the shack. I expected a virtual clone of my DR-638 and to a point it is but there are some distinct differences.
For the most part I like it but there are some quirks:
All in all this is a worthy successor to my DR-638.
- The display is a lot smaller than I anticipated. In the car this could be an issue but at home it should be alright.
- The RJ45 mic jack on the side of the head is fine except that it forced me to mount the radio sticking out of the console much further than I would have liked.
- Apparently there is some programming error that I made that keeps the radio receiving in CSQ mode even though the channel is programmed for PL or DPL decode. Gotta figure that out.
- The included software is OK but there is a serious bug in that it crashes when trying to enter a frequency out of band. It displays an error message then quits the programming, so be sure to save early and often!
- The radio comes with a programming cable but it does not work in Windows 11. I had to dig out my old Surface laptop with Windows 10 to get it to work.
- Navigating in the software is a pain. One must use the mouse to move from field to field, the tab and arrow keys don't allow local movement.
- If you want to set a channel to RX only you need to open a channel sub-menu and select it. Total PITA for 100 rail channels I programmed in the radio!
- As far as I know there is no way to set a memory frequency to the VFO.
- It is extremely sensitive, especially on UHF. I am getting a GMRS repeater from the other side of the mountain at almost full scale with excellent readability that doesn't even tickle the squelch on the scanners or R8600.
- Once programmed it seems to work very well, the buttons and knob seem to be pretty intuitive.
- The display, while small, is very readable and the color choices are a nice touch.
- The TX audio is great according to those I have talked to.
- There is a USB-A port on the left side of the head that one can use for charging a cell phone or other device.
- Switching between the A and B bands is easy with the hand mic.
- The two sides of the radio each have their own controls on the head, it is basically 2 radios in one case that share a mic.
- You can use a standard Ethernet cable for the removable control head.
- You can also use a standard Ethernet cable to extend the mic cable.
- When you turn the volume to 0 the radio does not click or make any noise when the squelch is broken like so many other radios do.
