Anytone AT-D868UV screen color and date format
W4KRR
Coconut Creek, FL
#1
I upgraded my Anytone AT-D868UV to firmware 2.34 because I wanted the black screen. Now to be clear, this is permanent, there's no way to switch back and forth between the black and the old blue background?
Also, the date format after the upgrade is DD-MM-YYYY. There seems to be no way to change it to MM-DD-YYYY (or any other format)?
chief21
Summer - western NC; Winter - Tampa Bay FL
#2
For what it's worth, I haven't found any way to change either the black screen or the date format. It seems that it is what it is unless and until they might be improved with a firmware update. If you don't like the black screen, you could always revert back to the most recent firmware version.
W4KRR
Coconut Creek, FL
#4
I wanted the black screen, but I just questioned if it was possible to switch between blue and black in the 2.34 firmware. Apparently the answer is "no". That's fine, but I do wish I could change the date format to MM/DD/YYYY.
