Atlanta P25 w/ G5
Michigan
#1
I've been in Atlanta this week on business and brought my G5 with me, since the city of Atlanta is on a P25 simulcast system it seemed like the perfect receiver to bring.
Has anyone else successfully been able to monitor this system with their G5? I've tried the entire week and the G5 will not lock on to any control channel. I'm perfectly open to the possibility it's a programming issue but I have tried just about every configuration possible, including putting every single frequency in for the system. I've also verified the system ID and WACN with my Whistler scanner using pro96comm so I am pretty certain all those settings are correct.
I'm able to monitor a neighboring P25 system without any problems (Cobb County).
cpetraglia
Fairfax, VA
#2
Looking at the Data Base here, you should have no problem. Be sure your RFSS is (4) and Site is (1).
Double check Site ID and WACN.
Should only need the 4 CCs and at least one TG, then set monitor mode to on and you should be good to go. Add TGs as necessary. I would think that would be a very active system.
Michigan
#4
Ah, I bet it was the site configuration, I forgot about that. I'm back at home now so I really can't test, but I'm sure that was it.
