Attempting to do a first programming on a g5
Pyro658
Central NJ
#1
I have the G5 uhf d-700
I am attempting to download my radio plan and this message pops up” The protocol of the device is unspecified. “ . I don’t understand why or how to address it. Any help thank you
troymail
Silent Key
#2
Make sure you are using the PPS that matches/is associated with your firmware. Each firmware release comes with it's own PPS version.
Then, make sure you have selected the correct model from the pull-down list in the PPS. In most cases, the models at the top of the list of the ones you want.
Note: if you selected the wrong model for your profile, you should be able to create a new one and convert what you have to the "new model".
EDIT: I just pulled the battery from my G5 for "other reasons"... There is a model number listed inside the battery compartment... I believe the model number is on the box your radio shipped in also.
Pyro658
Central NJ
#4
So when I unboxed it someone else was here and took the card off that says “go to this website and download the pps” �� anywaysLools like I’ll be good to go here. Thanks for helping !
Pyro658
Central NJ
#6
yes i am programed. now i can't figure out why it is not opening the audio unless i push to listen. I have unchecked push to listen in each zone
LEH
Yorktown, Virginia
#8
Double check your settings in the PPS, also check each zone and knob selection. I've had the 'push to listen' problem a couple of times after doing changes to my programming. I am not sure if the problem is 100% self inflicted, a 50/50 between the PPS and me, or if the PPS just like arbitrarily changing some settings.
What I think happened is I was using my mouse wheel to scroll down to the page in the knob settings tab. When the arrow got over one of the 'drop down' windows, the scroll changed the setting and then moved on.
As far as I can find, the 'push to listen' is knob position (channel) unique. So check another channel for activity and sound.
Pyro658
Central NJ
#10
So this worked. I was searching for that post because I had seen it so thank you. Now I can’t get any of my digital trunk stems to scan. Not one. I live in a rich area of systems so being out of range is total BS.
System ID WACN were backwards! Ugh this little thing is the most complex yet simple thing I have ever programmed!
LEH
Yorktown, Virginia
#12
I have a couple of systems in my area that will work one day and not the next. For them I've used the wildcards for System ID and WACN (all "F's"). This seems to work as when the control channel is received the ID and WACN displayed are correct.
As Troymail and others have said, the RR DB information is not always correct. :(
Pyro658
Central NJ
#13
For my next question....
Every time anyone keys up to talk on the Monmouth county system, it makes a tone alert cutting the audio out. Any idea what is going on here?
Pyro658
Central NJ
#17
You have that TG for tone alert, instead of none.
Sent using Tapatalk
I just found this setting, it was in fact on default. Switched back to none. To everyone helping and replaying to me making bone headed mistakes, thank you. I haven’t had this many problems programming a radio/pager in a long time!
