ATTN:S.E. TEXAS PRO 106 users
garceneau
Port Neches Texas
Please help. I need someone in the S.E. TEXAS area to help with programming my PRO 106. Since Central Dispatch (Nederland, Port Neches, Groves Texas) went digital in Nov. 2010, I have had nothing but problems. I finally found someone to help me but the broadcast is cutting in and out. I can't hear a complete dispatch or reply. I can bring scanner to you for programming correctly. Thank you so much.
garceneau
ST-Bob
Worcester, MA, USA
Cutting in and out probably has nothing to do with programming but is related to poor reception. Install an outside antenna and good coax (not your typical RG-58) or get a better antenna to replace the OEM rubber-duck.
KC5EIB
Flower Mound, TX
If it "cuts out" about every 2 seconds, priority is on, turn priority off on any and all frequencies you have it set to ON and let us know if that corrects the problem.
garceneau
Port Neches Texas
Thanks so much for the reply about the priority. I had a friend check it for me and now it seems to be working better. Not cutting out in and out. Thanks again for your help.
