ProScan Audio stream to Android
N1GTL
CT
I'm trying to stream audio from my scanner using ProScan. I would like to connect to it from my Android phone. When I bring up the web browser, I can see and control the scanner but I cannot get audio. The port forwarding works but it seems like the audio stream is not compatible with Android. Before I spend a rainy afternoon pulling my hair out, am I missing a way to simply achieve this?
ProScan
Software Provider
Ontario, Calif.
It's not a Port Forwarding compatibility issue. I would first go to the Audio Control - Web Server tab and see if you have audio meter movement. If not then that has to be troubleshot.
