Aurora S/F
abqscan
DataBase Administrator
Moderator
AOA
5226 danube ct. Basement & 1st floor are on fire. 2 Female burn patients.
Was first reported as a St. vs Ct. and the units were lost until dispatch confirmed address with caller. O/F DTRS DCFD Ch 1, FG12
1145, fire is U/C in the basement
1147, one female pt. is being transported to university with 1st and 2nd degree burns. University is requesting pt is taken to children's instead.
1146, command requesting another engine to the scene.
1145, 2nd female pt. is being transported to children's.
1149, fire is U/C.
abqscan
Moderator
AOA
Why did the address get corrected??? They called out 5226 danube ct around 10 times to every unit asking for it, after they didn't get it right the 1st time.
jimmnn
Colorado
They had two scenes one for the house fire and one for where the two pts were located after first trying to drive them selves to the hospital.
But what is even more interesting South Metro units (medic and engine) arrived first on both sounds before any 6x's units.
Also no Aurora FD involved in this area as originally posted.
Both the burn pts are stable code 2 transports.
Jim<
Toneslider12
A suburban location near a metropolitan area
Per the dispatch traffic, the RP gave the first address as 5200 S Danube St. E62, E63 & M63 all arrived in that hundred block range and found that the address was bad. Dispatch re-confirmed with the RP and the correct location of 5800 S Danube Ct. was given. L35 & E72 were coming from the south and still getting into the area during the address change, so they made it on scene first at the real address. The patients were in a vehicle along Orchard a few blocks from the fire scene.
