Autodial in KPG-112dn
TxLobo
Central Texas
Working on a TK-5220.
as I understand the software:
1. program the channel and tone and name the channel
2. Under the DTMF edit set "Autodial" - the name of the action and program in my cap codes.
3. then under key assignment, choose a button as "Autodial" action
Write it back to the radio. When the user selects the channel, then presses the assigned autodial button to pull up the coding, all they have to do is Tx and it sends the tones.
I'm not finding much on help files on this software, so my apologies if I get some shaking their heads at me, I'm still learning.
kd4efm
EL98 Florida
Kind of at a loss here, but your on the right track, what is it your trying to accomplish?
TxLobo
Central Texas
Sorry about that...
I have a field tech that needs to test the EWMS alert sirens, in order to do that he needs to have his portable send / broadcast the tones while he is at a siren.
I think it's the autodial function in the software, but I'm not finding much documentation online.
I program the tones in the autodial function, then use a button on the radio to select that autodial, then when he keys up the portable it sends the tones?
kd4efm
EL98 Florida
Sorry about that...
Most likely, yes, why not hot keypad and just punch the dtmf manually?
autodial:
PTT and then SOFT KEY THE AUTODIAL and it will send the tones.
TxLobo
Central Texas
autodial:
The model of radio that he has only has the standard buttons instead of the DTMF pad. Thanks for the validation! I can test it with a dummy load, but I will need to do a live test with it... and him too of course.
