AWIN Discussion
03msc
Arkansas
I think I heard the control channel when I was searching for sites on Sunday. I don't recall getting an email about it being down.
Same - I haven't seen any alert about it being down or having issues.
@mshadwick - could it be that your programming got changed somehow and it has the wrong frequencies now?
mshadwick
SharkMadwick
Heavener, OK
It is not a programming issue. I am able to put other towers in and works fine. Just not working on 856.1875. I need to take a look at the antenna and feed line.
Thank ya'll!!!!
slobonmycob
Newbie here, can someone with more experience tell me if/ when the p25 phase ii transition is going to happen? Is it worth buying a phase ii scanner at the moment?
Also, I was glancing over the Talk-Group ID's for the AWIN systems and wanted to mention that quite a few are inaccurate/ missing, how can I contribute?
with love, slobbonmycob
03msc
Arkansas
Transition is in progress note but it will still be a little while before it is phase ii. However if I was buying a scanner I'd for sure to phase ii capable now.
As for updates, you hit submit at the top of the database page which needs the updates. Be sure you only submit verified information. Care has been taken to get it accurate. What are you seeing that's wrong...? You can tell us here but do use the submit feature to submit it.
