Well it could be many things or combination of them.
The band conditions might be real bad, or storms within
a few hundred miles of you, or both.
Your antenna might also be getting a static charge on it,
wind blowing across the wire can make this condition possible.
Your radio might be a bit flakey in that area of reception,
wide band receivers do not offer much filtering.
You could also have a bad insulator on an electric pole near
your house causing havic on the airwaves.
Maybe your in an area were BPL (Broadband over Power Lines)
is being tested, this will just kill reception.
Solar storms can kill reception for periods of time also.
This is just a few things that could cause you problem, I am
sure there are many more that I can't think of at this moment.
Try putting a ground on your receiver, some times this helps
get rid of static charges.
See if the noise is the same at all hours of the day, if not then it
would be band conditions.
May be some others can shine some light here.
I just thought I would give my 2 cents...
Take care
Danny
N4YEK
