BAE/G4S - Kingsport Area
Church Hill, TN
#1
Does anyone happen to know what frequencies G4S (formerly Wackenhut?) security uses at the BAE site in the Kingsport/Mount Carmel/Church HIll area?
Using the FCC license search, I've found everything licensed to G4S but none of those frequencies - about 100 of them - seem to generate anything more than an occasional static transmission.
I have a couple of BAE operations frequencies that work. Any help is greatly appreciated.
Chris
DonnieDog
Database Admin Deluxe
Elizabethton, TN
#7
I only know of 2 different frequencies they use. Check under the federal section near the bottom. One of them is NXDN I think but the other is analog clear.
