ch40n1k
After putting up a new antenna today, I can log Bald north. Is this site used much for Ft. Collins or is Horsetooth the best bet for picking up Ft. Collins PD etc.?
scanlist said:Stick with Horsetooth for Ft. Collins Coverage. FCPD, PFA and CSU are not consistent on the Bald Mtn site. I know as this is the only site I pick up at the daytime job in Boulder.
Phil.
ch40n1k said:Thanks Phil. I was noticing that was the case as I appear to be able to monitor the Horsetooth CC as well. Significant improvement considering I'm shadowed by Green Mountain and the hogback.
P.S. I'm more than familiar with your radiohacker site ... but are you the same Phil that checks in on the Monitoring net on Sunday nights?
Actually the information was my doing back then. It was a fun challenge for myself before the digital scanners came out.ch40n1k said:In the early days of DTRS, the owner of this site posted all kinds of DTRS info and even a Win96 .p96 file ... which isn't valid any longer. I think there was a lot of pre DTRS frequency info as well.
The RH site owner has a daytime job that takes a lot of his time along with my getting out of publishing the scanlist after 20 years has unfortunately had an impact on the site.I'm not sure what happened, but the site isn't maintained any longer ... (correct me if I'm wrong)
Well, either way, your information helped me along quite a bit. I was just getting back into scanning after many years when I came across the scanlists and the RH site 5 or so years ago.scanlist said:Actually the information was my doing back then. It was a fun challenge for myself before the digital scanners came out.
Now when THIS website was trunkedradio.net it sure seemed interesting that the same info, including errors, somehow ended up here.
Since the digital scanners I supported with programming files are considered outdated I quit creating those files as well.
Phil.
