Bank Channels
Toms River
#1
The last scanner I had was 20 years ago. I could bank channels 1-10 10-20 so on.
Can I do that with the Baofeng uv-5rv2+
Thank you
Joe
Fortunately, GA
#2
To make this easier, click on the red and white triangle (report post) in the upper right of your post. Ask the mods to move your post to the NJ state forum where you will get better info.
Just so you know, your county has a Motorola Type II trunk system which requires a simple analog trunk tracking scanner. But, and this is a big but, some of the cities in your county are using P-25 and DMR. No Baofeng ham radio will allow you to scan those frequencies.
Whistler manufactures scanners that will do P-25 and DMR, but they are not in the price range of the CCR's. Nor, are the Unidens that you will see posted about.
HTH,
Larry
