Baofeng Baofeng dtmf select call
Gavin7
Does anyone know if there is a way to get baofeng radios (uv5r ect) to select call or open the squelch only if it receives a specific dtmf code
Gavin7
And if not is there any other radios in a similar price range that would support some kind of select call whether it’s dtmf 2 tone or other
chief21
Western NC (Summer); Tampa Bay FL (Winter)
There are many commercial radios that support DTMF and/or 2-tone and/or 5-tone encode/decode, but certainly not at Baofeng prices. Perhaps some used equipment could be found? At the lower end, certain AnyTone radios support these modes.
nd5y
Wichita Falls, TX
Are there any options for that in the radio menu?
Are there any options for that in Baofeng's programming software or CHIRP?
The answer to those questions should give you a clue.
dazey77
Anytone dmr radios also include some analogue signalling options I believe. Never tried it personally. Probably one of the lowest cost options (as chief also mentioned). Think they allow both 2 and 5 tone
cordelster
Livermore, CA
The Retevis RT85 supports many forms of selectcall. You have to use their software to access it. I'm actively trying to get this working now and was just searching for the difference in all the protocol types to determine what would be best for our groups use case.
I truly like the rt85 better than most the baofeng, though I wouldn't go to Retevis for any of their repeaters.
Gavin7
I’d almost forgot about this thread.
I’d be interested in seeing what you find out and possibly trying some myself. Maybe I have an excuse for another radio 🤔. How does the select call work?
Gavin7
I’ve heard apparently there are boards that you can add on to cheap radios for 2 tone ect. Also apparently some tyt radios support 2/5 tone
