Baofeng HT' to Baofeng HT' with CW-ID
INDEPENDENCE, Mo.
#1
I have two Baofeng HT's and I'm look for a cable that can connect them as a small watt repeater. I need the cable to have ID-CW capable. any suggestions?
Wichita Falls, TX
#2
None of the cheap VOX operated repeater cables I have seen have CW ID. You will probably have to build your own with a cheap repeater controller like an ID-O-Matic.
Why do you want to use Baofeng radios for a repeater? They have extremely poor receivers that overload and desense easily. There is no COS on the external connector. If you try to use them as a repeater don't be surprised if it doesn't work well.
