Baofeng UV-82 FM Broadcast Disabled?
gman4661
Got a slightly used UV-82 from a friend.
The FM function does not work at all. Could it be that it was disabled?
If so, how do I turn it back on?
Thanks in advance!
nd5y
Wichita Falls, TX
Do you have CHIRP programming software? It has a setting to enable or disable FM Broadcast. That is probably the only way to enable it. I don't know if the Baofeng factory software can.
gman4661
Don't have CHIRP yet. I was hoping for a menu option...
Thanks!
Kb2Jpd
New York City, NY
Thanks in advance!
You need to get the programming software and the cable. It is either disabled or programmed using one of the programmable function keys. Some are programmed with either a quick press or a prolonged two second press.
If you go to the Miklor website, you can download the manual in PDF format for computer viewing.
Adam Kb2Jpd
Kb2Jpd
New York City, NY
Adam Kb2Jpd
CHIRP can be downloaded from http://chirp.danplanet.com/projects/chirp/wiki/Home
CHIRP works on PC Mac and Linux including Raspberry Pi.
gungatim
you could try menu option 40 - restore defaults. there are 2 options, 1-all is total reset. you will have all frequencys and things erased, but it may work if the default has the FM turned on...
gman4661
Good information. I did the reset and now the FM broadcast function works.
I'm really impressed with this little radio. I plan to use it mostly as a basic scanner. The flashlight and FM functions are a plus.
Thanks!
