Baofeng UV-82 use in Civil Air Patrol
Ted240
Southside, Virginia
Hello,
As an active member in C.A.P., I need to know if this radio is NTIA approved? I dont see why not. I can communicate with repeaters, and on simplex, and also program, and receive federal frequencies.
bill4long
Indianapolis
CAP frequencies do not appear to be within Part 90 frequency allocation.
Which means the radios probably have to be type accepted within a different regulation. NTIA certification is definitely required.
Modified ham gear that is not Part 90 certified (just about everything) is definitely NOT allowed on CAP frequencies.
ecps92
Taxachusetts
Your question should be directed to your Squadron Comm Officer who will likely as the Wing for direction, to ensure the radio is actually NTIA compliant
Hello,
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hello,
Did you already ask your Squadron's Comm Officer? Did you already look it up on line?
The RR court of appeals is not going to rule in your favor.
Ted240
Southside, Virginia
Drat. Well, does anyone have any suggestions for a good radio for C.A.P. use? And they need to be cheap. Im a minor, so I dont have income, etc.
mm
oregon
chief21
Western NC (Summer); Tampa Bay FL (Winter)
CAP is very stringent on meeting NTIA specs, so it's most likely that none of the Baofeng radios are approved for use on those frequencies. For a short time, the Wouxun 6x WAS approved for use, but that approval was withdrawn after further investigation.
A used Motorola or EFJ radio (on the approved list) would be your best bet, but be forewarned... getting those radios programmed could be a problem. Best to discuss this with your squadron communications officer.
AI7PM
The Intermountain West
https://comm.capnhq.gov/equipment/equipment.cfm
And if you are serious about CAP and SAR activities, Bofeng, Wouxan, and alike are NOT the equipment you want to depend on. Drop an EFJ, Kenwood, or Motorola? Dust it off and move on. Drop a Bofeng, it's history. Already saw it happen.
cmjonesinc
Looks like even ht1000's are on the list. Those are a dime a dozen now. Just make sure it's a cn or dn model. If you want something with a screen and still cheap the mt2000 will work fine. If you're needing something with p25 then a efj 5100 will probably be the cheapest and easiest to find.
