Baofeng Baofeng UV-82HP : ANI ID (reading)
Tehrecon
We have a fleet of Baofeng UV-82HP radios that are programmed with ANI ID's (PTT ID's) for each one, however does anyone have any pointers on how I could READ the ANI ID? Thanks in advance!
nd5y
Wichita Falls, TX
Baofeng radios are not capable of displaying ANI.
You would need to build a DTMF decoder or buy something like these:
Tehrecon
Interesting...are you aware of any portable radios that may display this data and still communicate on the vhf band? I know some radios I've used in the past, such as the Motorola XTS5000 had this feature, but you're talking about thousands of dollars. It would be used at a non-profit summer camp where we would try to monitor if someone's 'hot micing.'
nd5y
Wichita Falls, TX
I don't know of any off hand. Probably no cheap ones. Most of the higher end Icom, Kenwood and Motorola hand helds probably can.
bharvey2
I use MDC-1200 signalling at work. I have issued CS3000 radios to managers as they can decode and display MDC-1200 aliases. You might check with Connect Systems and see if they can decode other types of signalling as well.
R8000
Very Low Battery
A true commercial DMR radio with a display will show radio id's very nicely.
