Baofeng UV5R Volume control
N2OAD
Forked River, NJ
Having problem with my 2 yr old UV5R. The volume control is scratchy. It only works on loudest setting. The rest of the radio is working fine. Can the volume control be cleaned and what's the best way to clean it or should I just get new radio since it's so cheap?
Thanks in advance for the suggestions.
Joe
N2OAD
khaytsus
Joe
N2OAD
You could always try any contact cleaner stuff. Has it been getting progressively worse? It's possible it's wearing out; I bet they're not high grade components. But worth trying to spray it out. Just make sure you don't use anything with lubricants in it.. I've seen some contact cleaner that's also a lubricant.. I'm not sure why in the world they would put the two together.
N2OAD
Forked River, NJ
Thanks for the reply.. I don't think it was progressive..Just started acting up and only works towards the loudest volume..as you try to lower it get scratchy or has no volume
teufler
ST PETERS, MISSOURI
if you take the volume control and open and close it several times, does this seem to work. That would indicate, the pot is dirty .
HelixArray
TN
I've cleaned oily trimmers before with CRC electric cleaner 5013. Even though it says it's "quick dry", it still needs to dry for a while in encapsulate areas; plus with any condensation in a hot/humid area that compressed cans give you.
