Baofeng Uv5R won't scan
kenstogie
Upstate NY
So I manually progam various frequencies in my new Baofeng uV-5R .....they are in there I can scroll through them using the up and down buttons.....
HOWEVER
When I hit the * (scan button) is just scans channel 0 and 127 back and forth.
What the heck is going on?? I tried turning it off and on....
I am new to this radio and in general but I still think the Baofeng is a great radio for the coin though just have to figure this out....
Aero125
Los Angeles, CA
Miklor.com is a great resource for anything UV-5 related. Keep in mind Baofengs are not designed to be a 'scanner' and the scanning function it does have is very poor and slow. If you do program in any frequencies you are not authorized to use, do not transmit on them.
Alot of Ebay sellers are advertising the cheap chinese transceivers as "police/fire scanner radios" which is very misleading.
kenstogie
Upstate NY
I know they arent scanners but have rudimentary scanning functions but for the 5 channels i would scan it would do the trick..... gotcha on the ptt button...just listening.
dmg1969
Newport, PA
Open the radio in Chirp and see if the other channels you have programmed are locked out. That should be indicated by an S in the Skip column.
